I'd like to do a radial sort that apply an change on the first object and then increaingly all the way around till i reach the last object.
Check out the attached image to make more sense.
For example: I have an array of sphere and I'd like to change there diffuse color from white to black based on the radial array. Check out the image to make more sense. For the sake of the image i just did it by hand.
JokerMartini
Comments (24)
I need to figure out how to return an array which is the order of splines in a shape, but in an order based on the radial sorting of the first knot in each spline.
I've hit this wall and I've been at it for the past few days and I'm now seeking some help from anyone. I hope that makes sense. I've attached an image to help explain incase your up for the challenge.
You may be wondering why I don't just create the splines in a radial order but that is because they are randomly created based off ob particle positions.
Anyways, the knot circled in red is just to show which knot is the first knot in the spline. The number by each spline shows which spline in the splineshape it is.
So ideally the returned array if radial sorted properly wold return this
#(1,3,5,6,2,7,4,8)
The Solution
Try this code on attachment file. Select any point helper and run code
fn RemoveItemFromArray arr itm =
local idx = findItem arr itm
if idx == 0 then false else deleteItem arr idx
pointArr = $Point* as array
if selection.count == 1 do
posArr = #(selection[1].center)
itm = selection[1]
while pointArr.count != 1 do
minDist = amin (for p in pointArr where p != itm collect distance itm.center p.center)
format "minDist = %\n" minDist
nextnode = (for p in pointArr where p != itm and (distance itm.center p.center) == minDist collect p)[1]
pointArr = RemoveItemFromArray pointArr itm
itm = nextnode ; append posArr itm.center
format "posArr = %\n" posArr
Great. Just what I needed. Let me play around with this code and see what I can do.
Any?
Has anyone been able to find the best way to radial sort. These seem to only work if the objects are on the x and y.
Using Raphael js and Jsfiddle
http://jsfiddle.net/SquDT/
Thanks!
hey
Nice test result.
Idea
It would be cool to make a pickbutton allowing a user to choose the first object in the radial array to start from.
Results from Anubis's latest version
clearListener()
local theObjects = getCurrentSelection()
local count = theObjects.count
local center = [0, 0, 0]
for obj in theObjects do center += obj.pos
center /= count
fn angularSort obj1 obj2 = (
in coordSys (transMatrix center)
obj1[3][2][3].value - obj2[3][2][3].value
-- create points (in case the objects has not Z_Rotation controller)
tmpPoints = for obj in theObjects collect
Point pos:obj.pos name:(obj.name+"_")
qsort tmpPoints angularSort
sortedArray = #(); sortedArray.count = theObjects.count
for i = 1 to tmpPoints.count do (
sortedArray[i] = getNodeByName (trimRight tmpPoints[i].name "_")
for i = 1 to theObjects.count do
obj = selection[i]
obj.wirecolor = [i*10,i*10,i*10]
moveKeys Obj (i*.1)
delete tmpPoints
print sortedArray
haha, fun...
I end with very fun anim result using attached scene :) I see you loop through in input/unsorted array theObjects insted of sortedArray, but nm, forgot this version and read Garp notes.
Garp
Quick Testing result to see the ordering based on wirecolor
center /= count
point pos:center
local ang1 = atan2 obj1.pos.y obj1.pos.x
local ang2 = atan2 obj2.pos.y obj2.pos.x
ang1 - ang2
qsort theObjects angularSort
for i = 1 to count do format "%\n" theObjects[i].name
obj = selection[i]
obj.wirecolor = [i*30,i*30,i*30]
And another one.
The cross product didn't diffentiate vectors aligned in the same direction or in opposite directions.
this is better, thanks
it sort CCW and start from 14 (in my example .max). I modify the code and I'v got sorted CW result from 1 to 18 like this:
Well...
... once the objects are sorted, it's fairly trivial to shift the array and/or reverse it.
Also, this method doesn't care if the objects are in a circular pattern or not, not even if they are planar. It just sorts them by their angle as seen in the XY plane from their averaged position.
yes, nice catch
just looking for better way, nm :)
And another thing.
With your modification, it looks like you're now sorting the objects based on their own rotation instead of their angle from the center.
Different approach.
First a center is determined by averaging all the positions. Then the objects are sorted depending on the sense of rotation as seen from the center.
This is done in the XY plane (rotation around the Z axis).
alright, ill do that. Quickly testing it is having a problem.
It's mainly just bugging out on this particular line of code.
is there an example scene that i could try testing it on that works for you?
obj1Pos = Point2 sortedArray[1].pos[1] sortedArray[1].pos[2]
Ok
Attaching a scene file to test it. Note that now I see so my function return correct result only if the objects center match the origin (ie 0,0,0). I like Garp approach (at the first look) but it not return the objects in circular order. In my test scene (with 18 boxes) if they are in CW, s'd been sorted - Box01, Box02 ... Box18, and if CCW - Box01, Box18, Box17 ... Box02. Garp function looks cool but return them in order - 8, 7, 6, 5, 4, 3, 2, 1, 9, 18, 17, 16, 15, 14, 13, 12, 11, 10. Ah, and very strange but if run Garp code line by line - the result is different - start with 17, next 16, 15, ... next to the last 1 and last 18, which is correct order, just start from 17.
I've discovered why the error
It's erroring out because the array is empty.
I wrote this in (print sortedArray[1] and it is printing undefined.
for o in objs where o.pos[1] == c[1] and o.pos[2] > c[2] do append sortedArray o
Hi John
I have only one hypothesis about. Because the script get itself 1st object ("at 12 o'clock"), and if it X pos is not equal to the center X pos, then the script will fail. To test if this is the issue, enter in the Listener:
and then execute the code in the function line by line.
This errors as well for some reason?
this is the error i get
-- Unknown property: "pos" in undefined
-- Error occurred in getCircleObjArrayInOrder(); position: 500; line: 12
objs =$Sphere* as array
-- function limitation:
-- the objects must be at zero plane on Z axis
fn getCircleObjArrayInOrder objs dir:1 = (
sortedArray = #()
oldSel = getCurrentSelection(); select objs
c = Point2 $.center[1] $.center[2] -- get center XY coords
select oldSel -- restore previus selection
-- add 1st object ("at 12 o'clock") to the array
r = distance c obj1Pos -- get the radius
a = (360.0 / objs.count) * dir -- get the angle
for i = 1 to objs.count-1 do ( -- find the rest...
ps = formattedPrint [r*sin(a*i),r*cos(a*i),0] format:".2f"
for o in objs where formattedPrint o.pos format:".2f" == ps do append sortedArray o
sortedArray -- return result
-- if dir:1 (default) the order is CW, if is -1 then CCW
a1 = getCircleObjArrayInOrder objs -- sorted CW
a2 = getCircleObjArrayInOrder objs dir:-1 -- sorted CCW
try this
[code]-- function limitation:
sortedArray = #()
a1 = getCircleObjArrayInOrder boxes -- sorted CW
a2 = getCircleObjArrayInOrder boxes dir:-1 -- sorted CCW
Its Erroring out
It errors out and says this in the listener:
In the max scene i just have 12 spheres in circular array like in the image attached.
-- Error occurred in getCircleObjArrayInOrder(); filename: ; position: 187; line: 6
-- Frame:
-- sortedArray: #()
-- r: undefined
-- objs: undefined
-- dir: 1
-- a: undefined
-- c: undefined
-- obj1Pos: undefined
-- oldSel: #($Sphere001, $Sphere006, $Sphere009, $Sphere012, $Sphere015, $Sphere018, $Sphere021, $Sphere024, $Sphere027, $Sphere030, $Sphere033, $Sphere036)
-- No ""select"" function for undefined
-- Frame:
-- sortedArray: #()
-- r: undefined
-- objs: undefined
-- dir: -1
-- a: undefined
-- c: undefined
You execute the function without argument!
The 2nd (dir) is optinal but the 1st required.
Put your objects to array (for eg):
and use this array as argument:
