Put Pivot To Center modifier
By harumscarum · 2012-08-12
New forum topics are on pause. Signed-in members can reply to existing topics. Contact ScriptSpot if you need help.
hello
would be great if anyone could add Put Pivot To Center option to XForm modifier or create this one
thanks
MKlejnowski
Added another button
Try the second button. Other wise I am at a total loss as to what your trying to do.
	try(destroydialog xFormAdjustRO )catch()
	rollout xFormAdjustRO "Adjust Pivot" width:160 height:102
		----UI
		button ctoBtn "Center Object to Pivot" pos:[16,32] width:128 height:20 toolTip:"Have a XForm align its Gizmo so that the object can be centered to the pivot as if the \"Align to Pivot\" action with \"Affect Object Only\" was used"
		button ctpBtn "Center Pivot to Object" pos:[16,60] width:128 height:20 toolTip:"Have a XForm align its Gizmo so that the object can be centered to the pivot as if the \"Align to Pivot\" action with \"Affect Object Only\" was used"
		groupBox grp1 "Alignment:" pos:[8,8] width:144 height:86
		----FUNCTIONS
		fn affectXForm oORp=
			curMod = modPanel.getCurrentObject()
			if (classof curMod == XForm) then
			(--do event
				local GizmoTrans , copyTrans
				undo off
					disablesceneredraw()
					curObj = selection[1]
					copyObj = copy curObj
					modNum = finditem curObj.modifiers curmod
					maxOps.CollapseNode copyObj true
					CenterPivot copyObj
					difTrans = copyObj.transform * (inverse curOBJ.transform)
					copyTrans = copyObj.transform
					delete copyObj
					enablesceneredraw()
				undo "Center Xform" on
					curMod.gizmo.transform = inverse difTrans
					if oORp then curObj.transform = copyTrans
			(--print message asking to select a xform modifiers in the mod panel
				MessageBox "No XForm Modifier is selected in the modifier panel. To edit the Xform please select the XForm modifier in the modifier panel and try again."
		)--end affectXForm fn
		----EVENTS
		on ctoBtn pressed do AffectXForm false
		on ctpBtn pressed do AffectXForm true
	)--End xFormAdjustRO
	createDialog xFormAdjustRO
harumscarum
thanks
yeah, it center object to its pivot position, but i need opposite - put object's pivot to its center automatically (as modifier)
actually just one checkbox "center pivot" in existing XForm modifier will be enough
thank you anyway)
MKlejnowski
is this it?
Give this a try. Select the Xform modifier in the mod panel and click the button. Not sure if this is what your where looking for.
	rollout xFormAdjustRO "Adjust Pivot" width:160 height:80
		----UI
		groupBox grp1 "Alignment:" pos:[8,8] width:144 height:56
		----FUNCTIONS
		fn affectXForm =
			(--do event
				local GizmoTrans
				undo off
					CenterPivot copyObj
					delete copyObj
					enablesceneredraw()
		----EVENTS
		on ctoBtn pressed do AffectXForm()
