With the code below I get his result.
"name:Point01 pos:[5,5,5] rot:(quat 0 0 0 1) wirecolor:red"
but I want this to be the result.
name:"Point01" pos:[5,5,5] rot:(quat 0 0 0 1) wirecolor:red
The scene setup is just having a selection of a point helper/s and the run the code.
JokerMartini
clearListener()
for obj in helpers do
PtName = obj.name as string
PtPos = obj.pos as string
PtRot = obj.rotation as string
print ("name:" + PtName + " pos:" + PtRot + " rot:" + PtRot + " wirecolor:red")
SOLVED
NOTE: mb needs to be classed as a string in order to work
NOW: How to get the result to a messgebox
Thanks for the starting point guys but I was wondering how to get this result to a messagebox instead. Similar topic so I thought I'd shout out here.
the for loop results in the listener as:
Also if it can work then how to go about removing the
It's maybe not possible this way as the messagebox comes up as
. Any help is greatly appreciated.
just add line break "\n" at the end:
Thanks Swordslayer
When i run the script on multiple objects it is formatting them all onto one line in the listener. I'll need it to print each obj separately onto a different line.
If I understand it right, this could do it:
