Hi, I was hoping someone could wright a pre-render maxscript that would clear all the channel data from the vray frame buffer before the start of a new render.
3ds max 2014 sp4
vray 3.00
Thank you!
By daniel · 2014-03-19
3ds max 2014 sp4
vray 3.00
Thank you!
Comments (9)
Thnks
Thank you so much!
Guys, this functions is build in in the vray settings.
http://oi68.tinypic.com/27zyyhs.jpg
Thank you!)
Here is a possible approach. Executing this script before rendering will clear the Vray framebuffer and suppress the messagedialog of vray.
The script does not supress the message dialog of vray-Plse Help
Hi,Thanks so much for the script it could be a huge help, and I'm surprised it's not built into the function.
Anyway it's great but it doesn't supress the message, so it only rebder one image of a sequence and waits
for the user to allow it to clear the data. so it's not so effective at this point.
Please help!
Thamk you!
AWESOME
thank you!
remove script
i used the script works great, but like shultzo3d the window is not suppressed, also after removing the script, it still runs every time now. please help
vfbControl ()
vfbControl (#clearimage)
I'm looking for the same script
One of the best enhancements of Vray 3.0 version is render mask. But maybe Chaosgroup team forgot to make a "clear pre-render" checkbox for long sequence corrections beside Render Mask list. It's the solution to avoid render again the entire sequence.
