Poly Object to Script
By gramx · 2010-12-24
Hi
Has anyone got a script that will take a custon polygon mesh and output the code to build it in a max script. ie save out all the point and polygon data?
I am trying to make my own custom helper objects.
Gram
Comments (24)
Garp
Nice!
You might want to update the script before going any further though. The bug you found has been fixed (and in the Primitive Maker too).
Reply to Garp
gramx
Ah ha - All fixed in one line, well done!
on clone orig do buildTriMesh()
cheers
g
gramx
Cam Rig with custom helpers
Hi Just wanted to say thanks again for all your help :) I have finished my first camera Rig:-
I have attched the Max scene file and the helper plugins. Have a play, your welcome to use it also! It uses a Vray camera. I am going to make a crane Rig next. Always wanted one for creating realistic camera moves. I will be able to create some cool crane helper objects now :)
camrig2: bug fix - Updated helpers
Cheers
Gram
Garp
This one then:
http://www.scriptspot.com/3ds-max/scripts/helper-maker
Before looking at the script itself, run it and look at the plugin file it outputs.
What the maker scrip does is just write the plugin code to disk. The rest is essentially building the UI and checking if the plugin name and/or the plugin file are already defined.
If you look at the example code in the doc, you can see that the 'on getDisplayMesh' block returns a trimesh. So you just need to give the trimesh definition to the plugin.
Since you need to define it only once, don't put it in the block but outside in a function that is called by the 'on create' and 'on load' handlers.
To pass the data from the maker script to the plugin file, you do something like
local theVerts = for v = 1 to getNumVerts myObject collect getVert myObject v
format "v_arr = %\n" theVerts to:output_file
Same principle for the faces and edge visibility. The primitive version passes a few more things but it's basically the same code.
Hope that clarifies a few points.
And of course, Happy New Year guys! :)
Reply to Garp
gramx
Ha Ha
Cant beleive I missed that one! lol
Problem solved, Its been a very good learning exercise anyway.
Many thanks
g
Graph
yeah and usually you'd use the createInstance function to do that but i tried it here and it didnt work with the mesh
better use a TriMesh() to do that, have a look in the help how to build that, cant help atm, way fuked up
happy new year
edit: not at all garp, he's just learning some maxScript, your plugin is still cool
Reply to Graph
gramx
Sounds like you've had a good night!
Yes I have been trying the createInstance function without any success! I have also been looking at TriMesh and it looks like you have to use the .mesh function to define it, which I am already doing:- theMesh = copy meshObj.mesh. Cant find anyway round it ;(
Hope your feeling better soon!
g
gramx
Allmost done!
Hi
What I am trying to do is different as I am trying to define Helper Objects directly without building a mesh in the viewport and the passing it to the helper. With help(thanks) I have got the converting mesh to code working fine! What I am trying to do now is to define this mesh in memory and then pass this to the display mesh of the helper. At the moment what ever I try builds a mesh in the viewport which then needs deleting after being passed to the diplay mesh. I have put the code for a simple helper below.
plugin Helper Helper_Test
classID:#(0x1e6a3439, 0x18067b16)
category:"Standard"
extends:dummy
	local  meshObj, theMesh
	on getDisplayMesh do
		if meshObj == undefined then
			meshObj = execute "(mesh vertices:#([0,0,50], [-40,-40,0], [40,-40,0], [40,40,0], [-40,40,0], [0,0,0]) faces:#([1,2,3], [1,3,4], [1,4,5], [1,5,2], [2,6,3], [3,6,4], [4,6,5], [5,6,2]));"
                        delete meshObj
		theMesh
	tool create
		on mousePoint click do
		case click of
			1: nodeTM.translation = gridPoint
			2: #stop
I am trying too pass a tri mesh to theMesh directly so I dont create geometry in the max scene and then have to delete meshObj. Cant figure it out!
Cheers!
Happy New Year!
Garp
"a script that will take a custon polygon mesh and output the code to build it in a max script. ie save out all the point and polygon data"
Did I miss something?
Graph
by simply returning the var that holds the mesh at the end of the string to execute as it turns out ^^
local test = execute "#simple"
print test
Graph
nope thats correct,
just add a few lines to add that stuff to the string. if itd been that easy it wouldnt have been a good exercise, now would it?! ;)
Reply to Graph
gramx
Updated script
I have added a loop to check for any invisible edges and added a setEdgeVis to the string. see example below. I had to also assign the mesh to a variable so that I could reference it in the setEdgeVis function otherwise it wouldn't work! I still need to figure out how to add this as a nodeRef to the local scope of the pluginNode. I will keep trying! Thanks for being patient and all your help!
example:-
execute "(themesh = mesh vertices:#([-2.5,-2.5,0], [2.5,-2.5,0], [-2.5,2.5,0], [2.5,2.5,0], [-2.5,-2.5,5], [2.5,-2.5,5], [-2.5,2.5,5], [2.5,2.5,5]) faces:#([1,3,4], [4,2,1], [5,6,8], [8,7,5], [1,2,6], [6,5,1], [2,4,8], [8,6,2], [4,3,7], [7,8,4], [3,1,5], [5,7,3])); setEdgeVis themesh 1 3 false; setEdgeVis themesh 2 3 false; setEdgeVis themesh 3 3 false; setEdgeVis themesh 4 3 false; setEdgeVis themesh 5 3 false; setEdgeVis themesh 6 3 false; setEdgeVis themesh 7 3 false; setEdgeVis themesh 8 3 false; setEdgeVis themesh 9 3 false; setEdgeVis themesh 10 3 false; setEdgeVis themesh 11 3 false; setEdgeVis themesh 12 3 false;"
[code]
--mesh vertices: faces: --[ materialIDs: ] \
fn obj2Code obj =
if isValidNode obj do
local tMesh = copy obj.mesh
local nVerts = tMesh.numverts
local nFaces = tMesh.numfaces
local edges = #()
local verts = for v = 1 to nVerts collect getVert tMesh v
local faces = for f = 1 to nFaces collect getFace tMesh f
local str = "(themesh = mesh vertices:"
with printAllElements true
str += verts as string
str += " faces:"
str += faces as string
str += ");"
for f = 1 to nFaces do
if (getEdgeVis tMesh f 1) == false do
str += " setEdgeVis themesh "
str += f as string
str += " 1 false;"
if (getEdgeVis tMesh f 2) == false do
str += f as string
str += " 2 false;"
if (getEdgeVis tMesh f 3) == false do
str += f as string
str += " 3 false;"
tMesh = undefined
return str
)--END obj2Code FN
local tString = (obj2Code selection[1])
format "%\n "tString
tString
[\code]
Reply to Garp
gramx
Yes, its very similar to what I am doing. cheers
Graph
 bla bla
btw every geometryNode in max is essentially a trimesh (well at least the important ones 😛)
why dont you try to modify the function i made to also add code for setting the edge viz for the new object? its simple and you can make your helper way dynamic by saving the string with the geoCode in a parameter of the node... that way users can either choose between preset helper shapes or pick their own geo shapes... dont forget that for that you need a temp global var to pass the nodeRef to local scope of the pluginNode
Reply to Graph
gramx
edge visibility
I tried modifying your code to this to add edge visibility:
	--mesh vertices:<array_of_point3s> faces:<array_of_point3s> --[ materialIDs:<array_of_integers> ] \
	fn obj2Code obj =
 			local edges = #()
				local facef = #()
				append facef (getEdgeVis tMesh f 1)
				append facef (getEdgeVis tMesh f 2)
				append facef (getEdgeVis tMesh f 3)
				append edges facef
			local str = "(mesh vertices:"
				str += " faces:"
				str += " edgevis:"
				str += edges as string
				str += ");"
			tMesh = undefined
			return str
	)--END obj2Code FN
	tString
this adds edgevis: to the code but its not recognised in the mesh command. Just gets ignored when executed.
Looking at the help it appears that you can only set the Edge viz with the following command setEdgeVis
Am I missing anything?
Graph
nope
btw you should only create the node in memory, that way you dont have to delete anything, afaik that fn doesnt work with a mesh but hey something for you to experiment with :)
try:
meshobj = createinstance pyramid()
to understand what i mean
Reply to Graph
gramx
Custom Mesh Helper Script
Not sure how to only create the node in memory. It seems to work OK so far! I adabted the code from this forum :- http://forums.cgsociety.org/archive/index.php/t-288270.html
It also seems that standard helpers can only be tri-meshes and only display as wireframe.
I have added edge visibility to the code otherwise you get a horrable triangulated mesh helper!
 fn obj2Code obj =
   local edges = #()
    local facef = #()
    append edges facef
    local str = "local vertsArray = "
    str += "\nlocal facesArray = "
    str += "\nlocal edgeVis = "
   tMesh = undefined
   return str
 )--END obj2Code FN
  output = newscript()
 format "%\n "tString to: output
--end
The code now outputs a new script in the following format:-
local vertsArray = #([-2.5,-2.5,0], [2.5,-2.5,0], [-2.5,2.5,0], [2.5,2.5,0], [-2.5,-2.5,5], [2.5,-2.5,5], [-2.5,2.5,5], [2.5,2.5,5])
local facesArray = #([1,3,4], [4,2,1], [5,6,8], [8,7,5], [1,2,6], [6,5,1], [2,4,8], [8,6,2], [4,3,7], [7,8,4], [3,1,5], [5,7,3])
local edgeVis = #(#(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false), #(true, true, false))
I then drop this code into the following ---mesh--- section of the scripted helper plugin:-
plugin Helper Mesh2Helper
classID:#(0x15424e9f, 0x5f189e30)
category:"Standard"
extends:dummy
 local  lastSize, meshObj, theMesh, lastpshape
 parameters pblock rollout:params
size type:#float animatable:true ui:size default:1.0
rollout params "rt Helper Parameters"
spinner size "Size:" range:[0, 1e9, 1]
  if meshObj == undefined OR size != lastSize then
--------------------------------------------------------------- MESH---------------------------------------------------------------------------------
   meshObj = mesh vertices:(for v in vertsArray collect v*size) faces:facesArray
   for face = 1 to edgeVis.count do
   for i = 1 to 3 do
   setEdgeVis meshObj face i edgeVis[face][i]
   delete meshObj
   lastSize = size
  theMesh
tool create
case click of
2: #stop
on mouseMove click do
case click of
2: (size = length gridDist)
)--end
I have only tested it with simple geo, aslong as you give each helper a new name and a unique classID then it all works. I will try some more complex geometry next!
g
Graph
lets get this going
execute "(mesh vertices:#([0,0,51.5526], [-39.0721,-40.7057,0], [39.0721,-40.7057,0], [39.0721,40.7057,0], [-39.0721,40.7057,0], [0,0,0]) faces:#([1,2,3], [1,3,4], [1,4,5], [1,5,2], [2,6,3], [3,6,4], [4,6,5], [5,6,2]));"
evaluate that snippet î to see the result of what is so far..
the current function simply creates you a string that creates a mesh. to use it as code directly use the first line printed (a=createinstance code, mesh = a.mesh .. or something alike); otherwise use the string and execute it
doesnt have smoothing groups, matIDs or tVerts but you wont need that for a helper.
	fn obj2Code obj =
				str += " faces:"
				str += ");"
			tMesh = undefined
			return str
	)--END obj2Code FN
	tString
have phun
Reply to Graph
gramx
Pyramids
Cool, It makes a Pyramid!
I will have a go at making a scripted plugin to build a new helper object now.
Great stuff!
Gram
Reply to Graph
gramx
Custom Poly Helper
I have written a script to turn your pyramid into a custom helper(code below). Unless I am missing something it appears that you can only create wireframe helpers! If you run the script below it creates a wireframe helper pyramid. Is there anyway to display a shaded polygon helper?
-------------------------------- start
plugin Helper rt_Helper
classID:#(0x357d24c1, 0x52e1d978)
category:"Standard"
extends:dummy
meshObj = mesh vertices:#([0,0,51.5526], [-39.0721,-40.7057,0], [39.0721,-40.7057,0], [39.0721,40.7057,0], [-39.0721,40.7057,0], [0,0,0]) faces:#([1,2,3], [1,3,4], [1,4,5], [1,5,2], [2,6,3], [3,6,4], [4,6,5], [5,6,2])
delete meshObj
theMesh
tool create
nodeTM.translation = gridPoint;#stop
----------------------------------- end
gramx
That would be very cool, I have seen a few posts on the forum with people wanting to have a similar script!
gram
Garp
I have to write a 'make primitive' script.
If you can wait a few days...
