point dummys to face or mesh
By dussla · 2020-06-22
hi friends
always thank you for good help
i need some help
i have many dummy points
i would like to connect that dummy ---> make face
pls can you help ~~
Comments (9)
dussla
wow wow unbelivable~
oh my god
very simple and perpect
wow wow wow
really thank you
you are genius
thank you
dussla
hank you for reply
i have some point cloud 10 ~ 30 points
i would like to point clound to mesh
that is all ~~~
Reply to dussla
Panteleev Sergey
Actually it is the simplest way of meshing of a 2.5D "point cloud" available in max without any third-party plugins.
        -- select all helpers that you want to mesh and run the script
        -- splines are created at pivot point position of selected objects
        -- then these splines are used in Terrain compound object to create the mesh
	max create mode
	shp = SplineShape()
	for s in selection do
		index = addNewSpline shp
		addKnot shp index #corner #line s.pos
	updateShape shp
	terr = Terrain isSelected:true
	terrainOps.addOperand terr shp
Reply to Panteleev Sergey
titane357
Hi, Jahman.
Are you aware that I search for such a script for 10 years !!!!!
11 lines !!!!
I always needed to go to meshlab !!!!!
Thank you very much !!! :-)
david
Could you be a bit more clear in what you need?
