Is it possible to do this?
And without changing to Utilities Panel?
Just Measure Panel with Lock Selection On...
Or some other method do get live dimensions..?
I've checked miauu's tools, but they are to complex and not free...
By Piotr Glabski · 2018-05-09
Comments (8)
This is what I have been using to open the Measuretool Floater for a while. Works in max 2018 & 2019.
No idea how to get it to start with the selection lock option enabled though! I'm sure I found it on scriptspot though.
Sure it is possible.
I guess I've seen this script already somewhere - and I remember the same error...
It switches to Utility panel, but nothing more...
Max 2019...
MAXScript MacroScript Error Exception
-- No ""get"" function for undefined
OK
It was written yesterday so it's unlikely. :) But many scripts use similar approach to handle UI.
Maybe someone who have max2019 installed could help you modifying it to work.
I guess you noticed that AD changed max UI pretty heavily, and that's the main reason why some scripts can't work in new versions as expected.
You were most helpful anyway, than you for your help.
I wish I had programming skills - I see how much can be easier and better in 3Dmax with MaxScript, I've try to learn so many times, but I'm litte "slow" in that matter.
(I've try your script also in 3DMax2018, same error)
Piotr
This works in max 2020:
Test it in max 2019 and if the error occur - post here the full error message. Most probably the line in which the error happens will be written in it.
Open Measure Floater New Floater.
Thanks for that.
The script takes me to, and opens, the Measure Tab. But it doesn't create a New Floater.
Ideally I want to open a New (Measure) Floater and place it to a particular place on the screen.
How can I do that?
Thanks again
it was written for older max versions, so it doesn't work in QT interface
change it like that and it will work as expected
