Any way to use object paint native from 3dsmax with snap?
I want to copy one object in many vertex that I have to pick in top view
Something like copy in autocad, select your object, your vertex and copy with snap where you want
Why snap is off with objectpaint?
Comments (9)
@barigazy : little advice : to work with group/many selection you can make helper [point, grid] and then make it as parent , that way you can have really selection min [from helper tho]....then you can move arround those parent...when the business done you can do de-parent and then ungroup if you have a group.
I found an example on cgsociety about it, btw vid you can use it too....
Hi Fajar, I have some error
http://prntscr.com/2wzxmo
I've deleted "!REG3XP1!>" and it only move my object to point with snap I want (is one step). Is good but I need copy the object, not move, and more than one time, every time I pick it copy ( would be great esc or right button to finish script)
I think is the way :D
not correct place, sorry
Thanks barigazy, I tried it and other scripts, but no snap function
I only need snap to use with object paint or similar, but with all, snap turn off
Most of these tools use mouseTrack function which disable snap after first click.
It's not so easy to create custom function which will have both methods included.
Well, I don't need mousetrack function, is possible make something to copy one object from one of its vertex (or pivot if is easier) to any vertex I pick with snaps?
I know you know but see this video, is exactly what I need and I think is very useful
Only a few seconds, until 2:25
http://www.youtube.com/watch?v=bpsEuvBiAgk&feature=player_detailpage#t=1…
Placing the object on the snapped vert is not a problem.
Watch this video from 4:00 min
By the way, what is the problem to use Paint selection to select the vertices and then to use script to place objects on the selected vertices?
Your script is great miauu but I search something simpler.
One button, pick, select object and then copy in every snap that I have actived. No rotation, no scale, no attach forever... only instance my object in selected snap
Use this tppl instead
http://www.scriptspot.com/3ds-max/scripts/autoplace
