object name -> edit text box show
By dussla · 2012-06-14
if i select object , i would like to be showed object name in editbox
is that possible ?
Comments (14)
fajar
Name Tools
global reNman
global objinSel
try (destroyDialog reNman) catch()
rollout reNman "Rename Tools" width:156 height:46
	editText edt_InText "" pos:[0,3] width:151 height:19 enabled:false
	button btn_ren "Rename Object" pos:[4,25] width:150 height:19 enabled:false
	fn objInSel=
		if selection.count ==1 then
			edt_InText.enabled =true
			btn_ren.enabled =true
			edt_InText.text=$.name
		else if selection.count>=2 then
			edt_InText.text=""
			edt_InText.text=selection[1].name
		else if selection.count==0 do
			edt_InText.enabled =false
			btn_ren.enabled=false
			edt_InText.text=""
	on btn_ren pressed do
		undo "rename my object" on
			for i in selection where selection.count!=0 do
				i.name = uniquename (edt_InText.text+" ")
	on reNman close do
		callbacks.removeScripts #selectionSetChanged id:#ObjNameCall
	on reNman open do
		callbacks.addScript #selectionSetChanged "renman.objInSel()" id:#ObjNameCall
createDialog reNman
it's little bit oto , see the script....its use callback to call the name of object, theres 3 action, if none selection, if selection==1 , and if selection +2 or more....
Press "E"(EditMode) checkbutton if you want to change name of selection.
Press Enter Key to assigne new unique name to selection.
This is the "Renamer" script
try (destroyDialog ::test) catch()
rollout test " Renamer"
edittext et "" pos:[-2,2] fieldwidth:146 height:17
checkbutton chb "E" pos:[151,2] width:17 height:17 tooltip:"Edit Mode"
timer checkSel "" interval:200
on checkSel tick do
if selection.count == 0 then (et.enabled = false ; et.text = "") else
et.enabled = true
if selection.count == 1 then et.text = selection[1].name else et.text = "Selected Objects: "+ selection.count as string
on chb changed state do
if state then checkSel.active = false else checkSel.active = true
on et entered txt do (for o in selection do o.name = uniquename et.text)
createdialog test 170 21 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
You looking for this
rollout test " test"
edittext et "" pos:[-2,2] fieldwidth:146 height:17 readonly:true
on checkSel tick do
if selection.count != 0 do
createdialog test 150 21 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
thank you but...
thank you for good answer
some more ask...
in text box , i can see object name
i have to modfiy that text little -> apply modify name to other object
but that is only read mode ?
can you understand ? sorry my poor english
JokerMartini
For what reason? do you want to chance the name of it or something?
Reply to dussla
  • i would like to apply many other script
  • Not understand your question
    okay i see
    if i select 1 object , that name is showed
    but i can see only , i cant edit that text
    example )
    seleted object name : used-car-model
    wanted object name : used-car-new
    if i edit text-box , only i deleted - model and add - new
    but if i do not eidt text-box , i have to write all letter
    do you understand ?
    Reply to dussla
    not quite entirely :)
    Send a screenshot to see what do you want exactly
    i seen now
    i seen edit mode script
    that is perpect
    you are sun
    you are genius
    very very very very thank you
