hello again
i made proxy -> mesh
this code is well in 1 select proxy
but if i select multi proxie , that code is error
what problem ~~
rre = #()
for o in selection as array do
If classof o == VRayProxy then
rre = vrayMeshImport o
select rre
$.pivot = $.center.x,$.center.y,$.min.z]
$.pos = [$.pos.x,$.pos.y,0]
$.transform = o.transform
clearSelection()
delete o
)else()
This code is for you
You have 4 arguments in this FN
- *nodes - selection of vrProxies
- *pivot - place pivot at center, top or bottom (options:#center, #top,#bottom)
- *deleteProxy - remove existing proxies after conversion (options: on or off)
- *placeOnGrid - place mesh on grid (z=0) or keep position (options: on or off)
fn vrProxyToMesh nodes pivot:#center deleteProxy:off placeOnGrid:off = if nodes.count > 0 do
object = for p in nodes where isKindOf p VRayProxy collect p
if object.count == 0 then messageBox "Select vrProxy Objects!" title:"Warning" beep:off else
for p in object do
node = vrayMeshImport p
node.pivot = case pivot of
#top: point3 p.pos.x p.pos.y p.max.z
#bottom: point3 p.pos.x p.pos.y p.min.z
#center: p.center
if placeOnGrid do node.pos.z = 0
if deleteProxy do delete object
vrProxyToMesh selection pivot:#bottom deleteProxy:on placeOnGrid:on
there is problem ~~
i test that ~~~
that is not accepted~~
can you some fix ~
