Hi everybody!
I'm new here and totaly new to maxscripting.
I've looked around and it seems possible but no clue how to get
it going. I'm looking for a script that will allow me to resize
the bitmap texture of a selected object.
For example a cube in scene has an 512x512 diff map assigned to
it and I would like to bring it down to 128 x 128
If anyone can steer to a right direction it would be much
appreciated.
Thank you!
RK
Thanks! I think the problem is if I execute with the numPAD enter.
When I drag drop the script it seems to work fine.
Watch this video.
Max2013.
Sure thing, will send it shortly. I'm using Max 2013.
Can you upload the test scene? Which max version?.
Thank you for the quick response Miauu
I went through it and slowly understanding scripting better.
But when I ran it I got this error from the listener:
-- Error occurred in anonymous codeblock; filename: ; position: 818; line: 28
-- Syntax error: at ), expected
-- In line: )
I can't seem to find the answer anywhere :/
Try this:
