Move group to center of screen
By Remy · 2018-08-13
So i actually already have a script that works a bit like this. The problem is that it only works for a single object/proxy.
What i would like is to be able to select a group - run the script - and that the group moves to the center of my viewport.
What happens now is that all the object within the group are move to a single point too. I like to maintain the structure of the group.
Hopefully somebody can help me improve the current script.
Thank you.
Remy
I noticed that when you select multiple groups/objects, that not all get centered but just one of them. Could this might improved in order to make it work with multiple selected objects/groups?
Thank you :)
Reply to Remy
	fn getXYViewIntersection =
		local intersection = [0,0,0]
		local viewTM = inverse (viewport.getTM())
		case (viewport.getType()) of
			#view_left: (manip.msYZPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
			#view_right: (manip.msYZPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
			#view_top: (manip.msXYPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
			#view_bottom: (manip.msXYPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
			#view_front: (manip.msXZPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
			#view_back: (manip.msXZPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
			default: (manip.msXYPlane.intersect (ray (viewTM.pos + 10 * viewTM.row3) viewTM.row3) &intersection)
		intersection
	function FindTopMostGroupHead obj = if isgroupMember obj do
		while obj != undefined and (not isGroupHead obj or isGroupMember obj) do
			(obj = obj.parent)
		obj
	if selection.count != 0 do
		selObjsArr = selection as array
		objsArr = #()
		for o in selObjsArr do
			grpHead = FindTopMostGroupHead o
			if grpHead == undefined then
				append objsArr o
				appendifUnique objsArr grpHead
		for o in objsArr do
			o.pos = getXYViewIntersection()
		intersection
			(obj = obj.parent)
		obj
		grpHead = FindTopMostGroupHead selection[1]
			selection[1].pos = getXYViewIntersection()
			grpHead.pos = getXYViewIntersection()
