Modification on this script... 3d ui align set a minimum handle length
By airbrush · 2011-03-04
I tried contacting the creator but no luck.
The script works great, but there is one annoying thing, the handle length is based on the selection of the verts. So if you have verts that are just slightly off and you run the script you have to zoom in a lot to see which handle alignment you are activating.
Basically i would like the handles to have a set minimum length so they are easy to see and select.
Anyone out there that could modify it to work, would be much appreciated.
thx
here is the script:
-- 3D UI Vertex Align Tool v1.0 --
-- Created by Trent Fealy --
-- www.studiosyntax.net --
global VertexAligner
global draw = false
global SelectedPoint = 0
global X = #([0,0,0], [0,0,0], [0,0,0])
global Y = #([0,0,0], [0,0,0], [0,0,0])
global Z = #([0,0,0], [0,0,0], [0,0,0])
global P = #([0,0,0], [0,0,0])
global screenpoints= #([0,0,0], [0,0,0], [0,0,0], [0,0,0], [0,0,0], [0,0,0], [0,0,0])
global BitVertArray
global VertArray
global amount
fn Align =
selectionarray = getCurrentSelection()
if classOf selectionarray[1] == Editable_Poly do
BitVertArray = polyop.getVertSelection selectionarray[1]
VertArray = BitVertArray as array
amount = BitVertArray.count
print "asda"
for i = 1 to amount do
if BitVertArray[i] == true do
original = polyop.getVert selectionarray[1] i
if SelectedPoint == 1 do
original[1]=X[1][1]
if SelectedPoint == 2 do
original[1]=X[2][1]
if SelectedPoint == 3 do
original[2]=Y[1][2]
if SelectedPoint == 4 do
original[2]=Y[2][2]
if SelectedPoint == 5 do
original[3]=Z[1][3]
if SelectedPoint == 6 do
original[3]=Z[2][3]
polyop.setVert selectionarray[1] i original
fn AlignInfo =
init = false
if init == false do
X[1][1]= original[1]
X[2][1]= original[1]
Y[1][2]= original[2]
Y[2][2]= original[2]
Z[1][3]= original[3]
Z[2][3]= original[3]
init = true
if original[1] < X[1][1] do
X[1][1] = original[1]
if original[1] > X[2][1] do
X[2][1] = original[1]
if original[2] < Y[1][2] do
Y[1][2] = original[2]
if original[2] > Y[2][2] do
Y[2][2] = original[2]
if original[3] < Z[1][3] do
Z[1][3] = original[3]
if original[3] > Z[2][3] do
Z[2][3] = original[3]
X[3][1] = X[1][1] + (X[2][1] - X[1][1] ) /2
Y[3][2] = Y[1][2] + (Y[2][2] - Y[1][2] ) /2
Z[3][3] = Z[1][3] + (Z[2][3] - Z[1][3] ) /2
fn redrawviews_callback_function =
if draw == true do
X[1][2] = Y[3][2]
X[1][3] = Z[3][3]
X[2][2] = Y[3][2]
X[2][3] = Z[3][3]
X[3][2] = Y[3][2]
X[3][3] = Z[3][3]
Y[1][1] = X[3][1]
Y[1][3] = Z[3][3]
Y[2][1] = X[3][1]
Y[2][3] = Z[3][3]
Z[1][1] = X[3][1]
Z[1][2] = Y[3][2]
Z[2][1] = X[3][1]
Z[2][2] = Y[3][2]
gw.setTransform(Matrix3 1)
p[1]= gw.wTransPoint X[1]
p[2] = gw.wTransPoint X[2]
mid = gw.wTransPoint X[3]
screenpoints[1] = p[1]
screenpoints[2] = p[2]
gw.setColor #line [50,171,248]
gw.wPolyline p false
gw.wMarker p[1] #smallDiamond color:[0,30,255]
gw.wMarker p[2] #smallDiamond color:[0,30,255]
gw.wMarker mid #smallDiamond color:[0,30,255]
p[1]= gw.wTransPoint Y[1]
p[2] = gw.wTransPoint Y[2]
screenpoints[3] = p[1]
screenpoints[4] = p[2]
p[1]= gw.wTransPoint Z[1]
p[2] = gw.wTransPoint Z[2]
screenpoints[5] = p[1]
screenpoints[6] = p[2]
screenpoints[7] = mid
if SelectedPoint > 0 do
gw.wMarker screenpoints[SelectedPoint] #circle color:green
gw.enlargeUpdateRect #whole
gw.updateScreen()
fn newselection ev nd =
AlignInfo()
completeRedraw()
tool MouseAlign
local MousePosition = [0,0,0]
local ClosestDistance =10
on freeMove do
MousePosition[1]=mouse.pos[1]
MousePosition[2]=mouse.pos[2]
SelectedPoint =0
ClosestDistance =10
for i =1 to screenpoints.count do
screenpoints[i][3] = 0
PointDistance = distance MousePosition screenpoints[i]
if PointDistance < ClosestDistance do
SelectedPoint = i
ClosestDistance = PointDistance
completeRedraw()
on mousePoint clickno do
Align()
VertexAligner.bbox.state = false
draw = false
completeRedraw()
#stop
on mouseMove clickno do
SelectedPoint =0
ClosestDistance =10
SelectedPoint = i
completeRedraw()
on mouseAbort clickno do
draw = false
completeRedraw()
rollout VertexAligner "3D UI Vertex Aligner"
checkbutton bbox "Align"
on bbox changed state do
if state == on do (
AlignInfo()
draw = true
startTool MouseAlign
on VertexAligner open do
unregisterRedrawViewsCallback redrawviews_callback_function
on VertexAligner close do
stopTool MouseAlign
completeRedraw()
createdialog VertexAligner width:100 height:100 style:#(#style_toolwindow,#style_resizing,#style_sysmenu)
airbrush
Thanks for the modification.
br0t
try using " ... " (without
try using ["code] ... [/code"] (without the ") to make your posted code more readable
Go here
airbrush
Anyone care to crack at it?
thx
