Maxscript file structure renaming
By Carter · 2020-08-25
Hello I am looking for a simple maxscript that will clean up my imported fbx files. This is straight forward just out of my realm of knowledge.
I need a file that will do the following in order
1. Delete all empty Dummy helper layers
2. Loop thru all Dummy objects and
  • A. Merge children objects of Dummy into one layer
  • B. Rename the newly merged layer to the Parent name +'_Mat"
  • C. Unparent the newly created layer
    5. Delete all empty Dummy layers
    6 Create a new Dummy helper layer
    7. Parent all geometry layers into the new Dummy layer
    Attached are two images showing an example of imported file structure and what I need the final file structure to look like.
    Names of layers will always be different.
    More than willing to pay for a working solution, not expecting anything for free.
  • Comments (3)
    I sent you a PM.
    Reply to miauu
    Carter
    Hmm, no PM but I will send an email from your site
    Reply to Carter
    Strange. It seems that PM not works properly.
    I sent you an em-mail.
