Guys,
could sombeone help me with quick little UI-less tool:
i have around 100 objects with different materials on them. Each material has proper name but object names are generic. I would like to select all objects and get all object names identical like material names, with "_SS" suffix.
So for example, if i have object that has material named "ground dry", after this script, corresponding object name would be "ground dry_SS". I need it in Max 2015 and objects could be parametric (box, sphere, etc), editable meshes or editable polys. No modifiers on them.
Thank you for your help !
Cheers
Perfect
Thank you Kostadin :)
