I have a material library files (mat) and want to export all materials names in this library to a xml file in this form:
where "ABC" is the material name in this library.
so how to do that or is there any script can do this task?
Thanks in Advanced.
Thank you very much i will try it
Thank you "pixamoon" for your help and info , i will check it and inform you.
Hi
There is a nice XML structure you can take a look:
http://www.scriptspot.com/forums/3ds-max/general-scripting/dotnet-xml-us…
and here is a sample how to read all materials names from mat files:
Can you tell me more how this xml should look like for multiple files and multiple maretials array? I can add this option to Library Track/Relink as export .mat info to XML:
http://www.scriptspot.com/3ds-max/scripts/library-track-relink
Cheers,
Pixamoon
Here is a simple/quick version.
If will find all .mat files in specified folder and create XML file for each of .mat file
Hope this helps
It working very will Thanks,
i just replaced the first line with
dir = getSavePath caption:"Choose .mat Directory"
Great example pixamoon
Is it possible to use matelement.innertext = and extract only the prefix or suffix of m.name with maxscript?
Lets say I have a material called Wood.Oakfloor.Dark and I want to output it like this
