Material ID Flatten Unwrap
By Chris · 2016-01-25
I'm a 3d artist and I don't know anything about scripting so would really appreciate help with this!
Basically I have lots of buildings to unwrap. So far the buildings have separate material IDs applied to them For each type of material (about 10 ids in total) such as concrete and metal etc.
Since I am using tillable textures I just need a quick flatten unwrap pack for each channel ID.
I think the scipt would do something like this:
Select Object
Select Material ID (1)
Unwrap Modifier
(in UV editor)
Flatten Mapping
Selected Inverted faces
Flip faces
Pack UVs
Collapse UV Modifier
Repeat.
Many thanks for any help with this
Chris
Áts Bálint László
Help! Doesn't work for me
I run your script and I got this message:
-- Unknown property: "Unwrap_UVW" in undefined
-- Error occurred during fileIn in
>> MAXScript FileIn Exception: -- No "map" function for undefined <<
-- Syntax error: at ), expected
-- In line: )
>> MAXScript FileIn Exception: -- Type error: Call needs function or class, got: undefined <<
Could you help me? This would be very useful for me!
Thanks!
Szeleczki Balázs
Hello. Maybe something like this? Select all your objects, and run it.
setCommandPanelTaskMode #modify
Objs = #()
Objs = for a in selection collect a
if Objs[1] == undefined then (messagebox "Need to select object(s)!")
else(
	for o in Objs do
		select o
		print o.name
		allIDs = #()
		for i = 1 to o.faces.count do
			index = polyop.getFaceMatID o i
			if (allIDs[index] == undefined) do ( allIDs[index] = #())
			Append allIDs[polyop.getFaceMatID o i] i
		addmodifier o (unwrap_uvw())
		for j = 1 to allIDs.count do
			o.unwrap_uvw.selectfaces (allIDs[j] as bitArray)
			o.unwrap_uvw.flattenMap 45 #() 0 true 0 true true
		collapseStack o
