Hi all, i'm working with nurbs object in max imported from rhino. the problem is that most format for import-export lose all the transformation position and the pivots are aligned to the world. so each obj while they are still the same one get a different pivot orientation. like in this image
i need to have the pivots aligned all in the same way so to can istance them correctly. like here
is there a way a script to align pivots on multiple objects without to do it manually one by one? without to be istances
mass pivots aligner
By jinj · 2011-05-22
thank you for the answer, but you suggestion doesn't work as mass modifier... just one by one.
i need to place the pivots oriented on the objects on each object... then i can istance them all in a go.
this should work; in te command panel set to moving the pivot only, press Shift+a, click the node you want the pivot aligned to.
however.. if you then instance/copy/ref one of them and move it some other place the pivot wont stay withe others as the mesh has a relative offset to the pivot
