Lock MAX UI
By Aslan · 2013-08-23
I'm looking for lock max UI, while my Script is open.
in the code below is a little code that open a new rollout inside other, but I wanna while second rollout is open User can't navigate or touch anything in MAX even previous rollout, just like when Align command open it's rollout and you can't do anything...
rollout test "test"
	button btn "Win"
	 on btn pressed do
		 rollout win "win"
			 button clo "Close"
			 on clo pressed do
					DestroyDialog win
		 createdialog win 150 150
createdialog test 100 100
Aslan
thanks
thank you very much.
Aslan
thanks vary much @barigazy
thanks vary much @miauu
Simply use modal properties of rollout
rollout test "test"
button btn "Win"
on btn pressed do
rollout win "win"
button clo "Close"
on clo pressed do
DestroyDialog win
createdialog win 150 150 modal:on
createdialog win 150 150 modal:true
When modal is set to true, the user can press buttons only in the current rollout. All other controls(in other rollouts and in MAX UI) become inactive. When the current rollout is closed you can press the controls in MAxUI and other rollouts.
