Hi all, i would ike to convert triangular mesh into 3d edges with triangular profile
i try tOu use lattice modifier on 3d studio max 2013 but i can't keep the edge continuity
how can i do this
thanks a lots
By ubikstudio · 2013-11-24
how can i do this
thanks a lots
any other idea?? pls help
thanks you, i just try this it but dont give me a clean intersection
The main problem is you can't weld more then two knots of spline and that's why edge continuity not exist. Try this:
Convert object to poly or assign Edit Poly modifier.
Select all edges and press "Create Shape from selection" button.
Select all knots of extracted shape and press "Weld".
Now assign "Sweep" modifier, change profiles and check "Gen Map Coords" and "Union Intersections"
