Keyframes and meshes
By k889 · 2008-08-03
Ok...so a person has a scene setup in 3ds max, there's a mesh "XXXXX" that is animated, it's using the physique modifier to attach itself to max's standard biped..
Is there a macro script or script out there that can:
1) select "XXXXX" then copy the mesh and rename it to "$XXXXX00" ( the mesh is at frame 0 on the time line at this point )
2) freeze "$XXXXX00" select "XXXXX", move to next frame, copy "XXXXX" and rename it to "$XXXXX01" then freeze "$XXXXX01", select "XXXXX", move to next frame, copy "XXXXX" and rename it to "$XXXXX02"...and so on ?
if such a script doesn't exist, would someone write one please?...thanks.
Anton Berg
I am glad it worked...
and I would highly recommend to go to the newer versions of max if you want other scripts to work, it has happend alot scriptwise since version 5 ;-)
Happy snapshoting!
OgmaSoul3D
Anton Berg
k889
Iam using 3ds max 5, but I recently got 8, haven't tried it out yet, but Iam going to soon..
cheers!
EDIT: Thanks a million!! it's working fine now :)
Anton Berg
What version of 3dsmax are you using?
I have tested it with 3dsmax 9 and 2008 and that works fine.
But if you are using a earlier version I am unsure if the "createdialog" command existed.
I have attached a different version which doesn´t use this feature.
OgmaSoul3D
Anton Berg
k889
Thanks for helping out! but there's a problem with the script, it says >> MAXScript FileIn Exception: -- Syntax error: at ), expected
-- In line: )createDialog snapshotMesh <<
and I forgot to include something crucial in my first post. sorry! i.e. "convert it to editable mesh"
1) select "XXXXX" then copy the mesh and rename it to "$XXXXX00" ( the mesh is at frame 0 on the time line at this point ) and convert "$XXXXX00" to editable mesh.
2) freeze "$XXXXX00" select "XXXXX", move to next frame, copy "XXXXX" and rename it to "$XXXXX01" and convert "$XXXXX01" to editable mesh, then freeze "$XXXXX01", select "XXXXX", move to next frame, copy "XXXXX" and rename it to "$XXXXX02" and convert "$XXXXX02" to editable mesh...and so on ?
Anton Berg
Hi I think that this might do the trick if it is Mesh you want... If you want polys I need to change it a little.
To run, just drag n drop the .ms file directly on a max viewport.
Usage:
1. Select the objects you want to snapshot, select the desired timerange and if you want a snapshot every frame. and press create.
Currently the naming is: objectname Fr framenumber. ex: Cylinder01 Fr 10
If you want a different standard for this just tell me!
OgmaSoul3D
Anton Berg
