Hi guys, I found this script and is all I need.
Uv to mesh
A bit like UVW Unwrap - but allows you to use any modifier to edit the UV's.
http://www.scriptspot.com/3ds-max/scripts/unwrap-mesh
But I can´t install (requires jbfunctions and I don't found them and seems very old. I use max 2011. Any script to translate uv to mesh and viceversa?
Thanks¡
The Channel Info utility (Utilities panel > More...) might be what you want. You can copy/paste mesh infos between all channels, including geometry.
try this one: http://www.scriptspot.com/3ds-max/scripts/uv-2-mesh
makes em planar right away :)
might help
Yes, I saw, but I need mesh 2 uv too, not only uv 2 mesh ;)
Solved
Well, I have solved in this way
Run uvwxyzswap script
Select all polys and make planar Z
Convert to edit mesh
Convert to edit poly
Run uvwxyzswap script and now all work fine with a 2d flattened version of your uvw
If possible modify script to make it automatically?
I have no idea of scripting :( sorry
Please, try uvwxyzswap script with this sphere. What happend? Why the xyz is not flattened?
Well, I found this
http://www.scriptspot.com/3ds-max/scripts/uvwxyzswap but it make a 3d version of uvw, I would need a 2d version flattened
