INSET / EXTRUDE Modifier
By Toby · 2017-01-10
I know that there is Face Extrude but I really would like to see a modifier that can be added to the stack that allows me to change the inset value without having to use an undo if I don't like the result. But the same applies to the extrude, it would be good to see an INSET/EXTRUDE modifier on it's own. I am surprised there isn't one around. I just dislike the Face Extrude modifier, it feels limited to me and it doesn't work in any other scale besides the default (ie CM, MM, FEET etc).
Can only hope someone will be kind enough to create one to share with us all.
Cheers :)
Vojtech Cada
Well, there's a MCG version but it currently splits the mesh into separate parts (you'd need to add a Weld modifier on top), so it might be better to send it as a suggestion to the official 3ds max ideas.
Thank you Swordslayer, I will try it out. Welding is not a problem, its just nicer to have better control..
Cheers for the link :)
