i made a box and i would like to apply edit poly automaticly
if $.modifier == undefined then
apply edit poly
pass edit poly
is that right ?
By dussla · 2012-07-26
apply edit poly
pass edit poly
is that right ?
Comments (9)
there is some problem
if $.modifiers[#uvwmap] == undefined do
addModifier $ (uvwmap())
if i use it , uvmmap modfidifer accumulate continuly
That's weird.
I copy/pasted your code and tried in max 2012. It worked fine.
So I tried it in old max 9 and sure enough it didn't recognize #uvwmap.
It does work with #uvw_mapping instead.
It looks like they change a few names between versions. Well done, Autodesk.
try thismax modify modeobj
try this
i can,'t use movdifiers.count
i have to apply 2-3 modfier in obj
so i can't use modifers.count
ex)
so i have to use
$.modifier[uvwmap] == undefined
modpanel.addmodtoselection(uvwmap()) ui:on
$.modifier[editpoly] == undefined
modpanel.addmodtoselection(eidtpoly()) ui:on
ok... try this other ... not believe to be the right way ... but I think it works, would be to use the correct "modPanel.validModifier (< modifier > | < modifier_class >)." but I could not make it work, look for in help...
thank you really
good work , thank you for your effort
always thank you
Or...
very good, simple and useful, I like... What it means "#" before of edit_poly ?
In this case it is used to pick a modifier based on its name. So if you have a modifier with a named "Edit Poly" then you will pick it by the name #Edit_Poly (replacing all spaces with underscore).
