If object name = something assign material
By JF Giroux · 2014-08-01
Hi all,
i'm looking for a way to look through all the scene objects and if an object name equals a specific name (ex. box01) then assign a material from a temporary matlib. I was able to create the temp matlib using the following code but can't make the selection part to work:
tempLib1 = loadTempMaterialLibrary "//Mylib/BOX01.mat"
matBOX01 = tempLib1[58]
$.material = matBOX01
meditmaterials[1] = matBOX01
thanks for your help
Comments (7)
wee chen
Assign certain material to certain object ?
Above script is very useful, but how do i assign specific material to specific objects ?
For example,
material BRICK to Ex_wall
Material SHINGLE to Ex_Roof
thanks in advance.
If your material library is located in default "matlib" folder then you can use
matlib = loadTempMaterialLibrary ((getDir #matlib)+"\\your_library.mat")
-- if you know name of some specific material in your librari then you can use instead of index number real name
meditmaterials[1] = matLib["Some_name"]
matLib = loadTempMaterialLibrary @"C:\Users\bga\Documents\3dsMax\materiallibraries\Walls.mat"
obj = getCurrentSelection()
index = 3 --3rd material in library
if obj.count > 0 and index <= matLib.count do meditmaterials[1] = obj.mat = matLib[index]
