Hello, i spent a lot of time on making this stuff and first time i release it, but second i couldn't make it again,
to delete last MatID(mesh) by 1 click, can someone help me with this ?
IT's a simple script when you select a mesh and press button - it deletes last MaTID(mesh).
P.S.
And if it possible http://dfiles.ru/files/owsepv1vr to modifie this script(its .psk file importer) and add to it a possibility to insert special mesh(On the importing model), while importing the file, with position controlling rulers.
Comments (24)
it works
Thx! it works,
Second question, http://dfiles.ru/files/owsepv1vr is it possible to modifie this script, it is importing psk files(that have mesh, bones and skin data)
I need a little modification, to attach a mesh(from folder - in 3ds format or obj) on import and to be able to change it's position using script ?
I'm in need of this for a long time, 3-6 months.
Thx guys anyway! for your time and work its helps me a lot.
Hey Artemie
Why don't you ask the author to add new features that you suggested
I did asked him, he doesn't have 3ds max anymore and he won't install it, if this future will be available it would save a lot of time,
or is to hard ?
Skin problem
--Update guys,
this script works perfectly even for meshes with skin modifier applied on!
Hey thx guys for helping me out, but seems script won't work with skin modifier applied on mesh http://i.imgur.com/ZOMKUIL.png
Is it possible to add little support - with skin applied ?
I tested anubis script on max 9 and its didn't work =(.
the script from the PNG is not mine ;-)
it was made by Branko and he already update and fixed it, so it works too now in Max 9, but the script you post above is mine, with some additional optimization mades by Branko, and if it works fine, then where is the problem?
try now
fn delMeshFaces obj =
local getFID = getFaceMatID, idArr = #(), lastID = 0, aFaces = #()
for i = 1 to obj.numfaces where ((id = getFID obj i) > lastID) do lastID = id
for f = 1 to obj.numFaces where getFID obj f == lastID do append aFaces f ;
meshop.deleteFaces obj.baseobject aFaces ; update obj
This is my test. Based on your solution I fixed memory lecking
First test scene (10 collapsed boxes)
Now your original code #1 solution
This is recreation of your code #2 solution
And now the result
time:0.064 memory:1485368L#1 solution
#2 solution
time:time:0.048 memory:129824L#2 solution is 10 time memory efficient and 1/3 time faster
thanks for testing
Interesting, I always thought that Collect is more faster than Append. Maybe I s'd test them again.
This is the replacement for "appendIfUnique"
and the final code will be
try(destroydialog ::testRoll) catch()
rollout testRoll "Delete LastMTLID Faces"
fn deleteLastMtlIDfaces obj =
local arr = #()
objFaceIDs = for f in 1 to obj.numfaces where (finditem arr (hVal = gethashvalue (fID = (getFaceMatID obj f)) 0)) == 0 collect (append arr hVal ; fID)
for f in 1 to obj.numfaces do appendIfUnique arr (getFaceMatID obj f)
lastIDFaces = sort (for f = 1 to obj.numfaces where (getFaceMatID obj f) == (amax objFaceIDs) collect f)
for f = lastIDFaces.count to 1 by -1 do deleteFace obj lastIDFaces[f]
free arr ; free objFaceIDs ; update obj
button theButton "Do the JOB!" pos:[5,5] width:140 height:40
on theButton pressed do
if selection.count != 0 do
for o in selection where iskindof o Editable_Mesh do deleteLastMtlIDfaces o
createDialog testRoll 150 50 10 110 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Did you tested my example function I post below?
I'm just curious is it worth :)
Yes i tested it. Also i check time and memory leaking and you have better solution for sure. Memory leak is the main problem in this aproch.
Hey, how do you setup "post below" hyperlink. Very cool
[link to this post is here]
Each post has link in it title ;-)
No "append" is fester from "collect" probable because for append method you already have defined array and for collect you build array on the fly.
Also is better to store mesh fn in local variable before use it multiple time (in for-loop or while-loop etc..).
By the way, is there easy way to get bigest mtlID number of geometry object.
I think that's poly method is more efficient (numFaces count is twice lower).
LOL
I'm sure that I done some test in the past to end with such conclusion that Collect is faster than Append :) Anyway, will test once again (some day).
Storing a function in variable,.. ya I know that helps in case the function is a Struct member, like meshOps for example, but not thought to test that for other (stay-alone) functions. So, it's help for them too?
As for easy way to get bigest mtlID, well,.. it's what I use in my function (for..if..x>y..y=x), at least don't know better :) We have #materialIDs named-prop in Mesh Constructor, but we cannot access it after that (on existing mesh), so sad, and the great ADSK is so lazy to make that property script-visible. If were exposed then all to code w'd been just this:
but... :)
Hey Panayot,
I know. I agree with you (laziness is a bad habit) :).
Also I wonder when Phyton become part of max. Like in Maya or Softimage or Cinema4d or Blender or ... 10 more softwares. .net is very useful but phyton ...
Thx you very much!
But it gives me error
http://i.imgur.com/HdlP72N.png
Sorry i forget to replace "$" with "obj" variable.
I fixed the code try now.
Try to avoid objects that have only one mtlID
sorry but its still gives me error.
http://i.imgur.com/oBbylT7.png
are you in Max 9 or below?
if so, there no
function, at least until install AVG (Avguard Extensions).
Yep. I think that "apendIfUnique" cause the problem here
You asked a script. Here we go
local arr = #()
lastIDFaces = sort (for f = 1 to obj.numfaces where (getFaceMatID obj f) == (amax arr) collect f)
update obj
I see you already helps here
The term "last MatID" is very funny... I need to read your code to see that this is translates as "most higher MatID" :)
Anyway, is next (untested) function is more optimized?
try this one
fn deleteLastMtlIDfaces obj = if iskindof obj Editable_Mesh do
local arr = #()
for f in 1 to obj.numfaces do appendIfUnique arr (getFaceMatID $ f)
lastIDFaces = sort (for f = 1 to obj.numfaces where (getFaceMatID $ f) == (amax arr) collect f)
update obj
--example
deleteLastMtlIDfaces $
