Hide / Show bones
By titane357 · 2013-06-20
Hello
I would like to show/hide bones by a toggle.
I found different scripts, but in max2014, these script can show bones but can't hide bones even with a redraw fonction ???
Anybody can help ?
Comments (9)
M Lup
this is working for me as toggle. Change category and names by your needs.
macroScript BonesToggle category:"Test" toolTip:"BonesToggle" (
if hideByCategory.bones == true then ( hideByCategory.bones = false)
else (hideByCategory.bones = true)
titane357
Thanks Barigazy, I found :
hideByCategory.bones = (not hideByCategory.bones)
it works on bones but not on bipedobjects...
strangely, "hide category" "Bone Object" is switched "on" by the script, but biped objects not hidden...
Reply to titane357
Code above not works in max2014 even if you force view redrawing.
Reply to Branko Živković
titane357
Thanks very much Barigazy, it works.
As I really want a shortcut : i'll keep ( one with "on" and another "off" )=
fn collectClasses optArr:#(cb_bone,cb_bip,cb_cat,cb_hub) =
for c in 1 to optArr.count collect
case c of
(1): BoneGeometry
(2): Biped_Object
(3): CATBone
(4): HubObject
fn hide_unhide_Skeleton state: =
local skeletonClasses = collectClasses()
(for b in geometry where findItem skeletonClasses (classof b.baseobject) != 0 collect b).ishidden = state
hide_unhide_Skeleton state:on
I'd be better with a switch ;-)
Reply to titane357
But how you can chack which option ei sceleton type you want to consider in process?
titane357
for now, I just need to hide/show bones or biped objects...
So nevermind if I can't choose for the moment.
Very annoying that in max you can toogle visibility for shape, geometry, light,... but not bones with shortcut...
So, your script is enough for me at the moment. Thanks.
Or if you want to no loop trough all scene objects then use simply
(for b in geometry where isKindof b.baseobject BoneGeometry collect b).ishidden = on
(for b in geometry where isKindof b.baseobject BoneGeometry collect b).ishidden = off
Can you try this
--to hide bones
(for b in objects where isKindof b.baseobject BoneGeometry collect b).ishidden = on
--to unhide
(for b in objects where isKindof b.baseobject BoneGeometry collect b).ishidden = off
