hi this is walid script
thatnk you for good script
i want mutiple object regardelss of group or non group object
macroScript ScaleTo category:"Walid" tooltip:"Scale To 1.0"
undo on
global xlength;
global ylength;
global zlength;
global target;
global ratio;
rollout unnamedRollout "Scale To v1.0" width:162 height:199
radiobuttons rdo2 "Reference" pos:[5,4] width:84 height:62 labels:#("X Coordinate", "Y Coordinate", "Z Coordinate")
label lbl2 "Scale To" pos:[5,72] width:44 height:19
spinner spn1 "" pos:[50,72] width:69 height:16 range:[0,1e+006,0]
label lbl3 "cm" pos:[130,72] width:20 height:19
checkbox chk1 "Reset Xform" pos:[5,104] width:131 height:26
button btn1 "Apply" pos:[34,141] width:99 height:29
label lbl7 "Developed By Walid Abou Ali" pos:[7,179] width:144 height:26
on btn1 pressed do
units.displaytype = #Metric ;
units.MetricType = #Centimeters;
if $selection.count ==0 then
messagebox "no object selected";
else if $selection.count > 1 then
messagebox "you can only select one object";
xlength=$.max.x-$.min.x;
ylength=$.max.y-$.min.y;
zlength=$.max.z-$.min.z;
target=spn1.value;
if rdo2.state==1 then
ratio=target/xlength;
else if rdo2.state==2 then
ratio=target/ylength;
else if rdo2.state==3 then
ratio=target/zlength;
scale $ [ratio,ratio,ratio];
if chk1.state then
resetxform $;
createdialog unnamedRollout
