Hi there,
I am in a great need for a script that takes the tedious detach button away :) Lets say i have a plane with 20x20 segments. Is there a way, by pressing a button to make all polys on that plane to a single object, So i end up with 20x20 objects? An extra awsome button or automation would be that it would make each poly then to make planar in x,y,or z! This would be needed if i use the conform tool an let the plane to drop onto something. Which will eventually change the polys shape. let me know if you need some more information
cheers
