Selected Objects Same BBox - set the bounding box size of selected objects to the biggest size on each individual dimension of the selected objects existing bboxes., If possible without having stray vertices in the resulting objects.
Example : Object01 BBox (x=2m y=4m z=1m) : Object02 BBox (x=3m y=1m z=3m) = Resulting BBoxes (x=3m y=4m z=3m)
BBox Changer - allows you to change bounding box sizes of selected objects simply by typing a integer in the X, Y, Z Dimensions within the rollout dialog, then click "Change" button. If possible without having stray vertices in the resulting objects.
selection.max and selection.min will give you the boundingbox min andmax coordinates of all selected objects. Watch this video: http://www.youtube.com/watch?v=4Jb9atTQotI
You will see how the script draws the bbox of selected objects.
As far as I know this:
is not possible.
