Greetings...
I need a script that can copy the "camera's name" and assign as the "output's filename" with a predefined extension like "tif"...
The emergence of this "need" became obvious after sending 6 different renders to backburner with same output file...(it warns me but tough deadlines can make you do that)
extra:
It would be best to combine the script with a "quick render" function at the end so that a single shortcut press would send it to back burner.
extra extra:
It could append fine name like take001,take002.... ("take" is for not it messing up the animated frames...)
Thank you for interest.
