Flip Faces on Selected objects?
By net_ralf · 2010-03-10
I am looking for a script that flips all the faces of multiple selected objects. I had to import a cad file and there are gazillions of small faces fliped. any idea? The script should maybe automated apply the normal modifier and then convert it to mesh.
Thanx in advance
Ralf
Graph
have phun :P
	---  brought --- to --- you --- by --- IN-Tools.biz --
	rollout flipFlop "FlipFlop"
		group ""
			checkBox unify "Unify" across:2
			checkBox flip "Flip" checked:true
			radiobuttons processType "Processing" labels:#("Single", "Group") align:#left columns:3
			radiobuttons meshType "Convert To" labels:#("Poly", "Mesh", "None") default:3 align:#left columns:3
		button Process "Process" width:(flipFlop.width-10) height:30 toolTip:"Go Panters!"
		on process pressed do
			with undo on
				local sel = selection as array
				local normalMod = normalModifier()
				normalMod.unify = unify.checked
				normalMod.flip = flip.checked
				if processType.state == 1 then
					for obj in sel do
						addModifier obj normalMod
						case meshType.state  of
							1 : (
								convertToPoly obj
							2 : (
								convertToMesh obj
							3 : ()
					)--END obj loop
					addModifier sel normalMod
						1 : (
							convertToPoly sel
						2 : (
							convertToMesh sel
						3 : ()
			)--END undo
		)--END process.pressed
	)--End RO
	createdialog flipFlop
Why don't you just apply a normal modifier as instance to all selected objects?
