Finding the right angle
By JokerMartini · 2015-08-03
I've im given a plane [yellow object in image] and a sphere [green object], how can i find the position of the right angle between the two objects? as demonstrated in the image below. I know 3 things which i assume will help find the solution
1. The position of the plane
2. The Normal of the plane
3. The position of the sphere
/* Test Scene Setup */
delete objects
pln = plane width:5 length:5 pos:[0,10,10] wirecolor:yellow
rotate pln (angleaxis 30 [1,0,0])
s1 = sphere pos:[0,30,0] wirecolor:red radius:2
center = pln.pos
normal = pln.transform.row3
JokerMartini
Completed!
nothing a little trig couldn't do
[code]
fn GetVectorsAngle v1 v2 =
theAngle = acos(dot (normalize v1) (normalize v2))
fn PlaceAlongVector pos:[0,0,0] vec:[0,0,1] offset:0 =
pos + (normalize (vec)) * offset
clearlistener()
format "\n"
delete objects
center = pln.pos
/* Find the length to create a right traingle */
-- get angle difference between 2 vectors
difVector = s1.pos - pln.pos-- vector between plane and ball
objVector = pln.transform.row3 -- vector using normal of plane
dist = distance pln.pos s1.pos
calcAng = GetVectorsAngle difVector objVector
-- calculate the length of side to create a right angle
len = cos(calcAng) * dist
-- place point which would create a rightAngle at the sphere
cornerPos = PlaceAlongVector pos:pln.pos vec:objVector offset:len
point pos:cornerPos size:2 wirecolor:yellow
JokerMartini
that is an interesting approach but id like to avoid doing the intersect ray stuff
Check the cgtalk thread.
Reply to miauu
JokerMartini
aside from what im trying to do on CGTalk, I'm still curious to know how one would find the right angle 'pos' like demonstrated in the picture.
Reply to JokerMartini
pixamoon
this is a way around but its very simple:
-it just copy your plane to center of sphere
-enlarge plane
-find intersection between normal or (-normal) vector and new plane
clearlistener()
delete objects
center = pln.pos
pln2 = copy pln
pln2.pos = s1.pos
pln2.width = 999999
pln2.length = 999999
if (a = intersectRay pln2 (ray center normal)) == undefined do a = intersectRay pln2 (ray center -normal)
-- if intersection is not found because normal direction is other way
-- it checks for intersection with flipped normal
pointPos = a.pos
delete pln2
a = point pos:pointPos
Reply to pixamoon
JokerMartini
Thanks for the alternate solution bud. I figured it out if you look at my first post.
