i used findstring for select same name object
example)
there is obj1 obj2 obj3 obj4 obj5 obj1 objs
in there , i would like to select obj1 name only
but if i use findstring function ,
that fuction collect all obj* objects
how can i select same name object with findsting fuction ?
Comments (8)
try this thing fellafn
....remember to add "" before and after the name object...but if youre using edit.text you dont need that
In most cases you need to add
"*"except you search for exact name.
Also "ignoreCase" argument can be important.
Use finditem
objNameArr = for n in $Obj* collect n.name
--#("Obj5", "Obj4", "Obj3", "Obj2", "Obj1")
select (getnodebyname objNameArr[(finditem objNameArr "Obj1")])
ok thank you pls , can you answer same layer
ok i see same object find way thank you
in layers
obj1 obj2 obj3 obj4 layers
how can i find same obj1 layer ?
Are you want to find out in which the layer is obj1?
yes
0. layer name in text box
1. collect layer name
2. current layer layer name in text box
or turn on layer name in text box
If you want to know obj layer name just use
$Obj1.layer.name
--or if you want to collect objs layer names (unique one)
layerNamesArr = #()
for o in $Obj* do appendifunique layerNamesArr o.layer.name
wow ,barigazy thank you
always thank you
you are my sunshine
if you help me , mabey i can't do anything
you are best kindly person
