Hi guys, how´s going?
i was thinking of a script that would apply an extrude modifier into a spline, using an object height as the amount. Example, select the spline, run the script, wich asks to pick the reference object, and then apply extrude modifier with the objetc height. Is it possible? too hard to code?
Thanks in advance,
Jsrocha
Wow, that's exactly what i need! Thanks a lot man!
Jsrocha
Extrude Spline by Reference
If I understand correctly this code should work as you said.
You can download the attached script and run it from 3ds.
To use it select one or more splines, then go to "Scripting -> Run script" and select the script.
A window will open asking you to select the reference object and voilà.
