I am needing to export only the group name without exporting the names of objects, only the group name on a list to send the client to separate the furniture, lighting etc.
Is it possible?
Export group's name to excel (xlsm) or notepad .txt or .doc etc
By Gabriel · 2014-08-10
I don't know abouth that limitation because never before print that count. Probabli is some memory problem. This works (1 million lines *.txt file)
fn printAllGroups txtFile =
array = for i in 1 to 1e6 collect i as string ; gc light:on
(dotnetclass "System.IO.File").WriteAllLines txtFile array
printAllGroups @"c:\temp\numbers.txt"
I have to find the script and the exact problem with writealllines.
Branko, for some reason(unknown to me) WriteAllLines have one dissadvantage - it can't print more than 80 000 lines. I think that was the correct number, or it is close to the correct.
In the past I created a script that prints about 300 000 lines in a single file. Then I discover that WriteAllLines can't help in such a situation.
BTW you can choose any file extension (.doc, .txt, xlsm)
Try this fn. Also change filename path
helper = for node in helpers where isGroupHead node collect node.name
if helper.count == 0 then messageBox "No Groups in the scene!" title:"INFO" beep:off else
(dotnetclass "System.IO.File").WriteAllLines txtFile helper ; free helper
printAllGroups @"c:\temp\SceneGroups.txt"
OMG
It's Perfect! That was very fast. I'm impressed.
Thank you very much. I can make a donation in return?
