Hi guys, how´s going? i need a little help, i think that´s an easy one. I create a spinner in wich a type a value. I store this value to use as a inner and outer value for shell modifier. But i need to divide this value by two, and then use it in shell. the code i´m using is this one (part of it):
button btn1 "Button" pos:[124,18] width:76 height:34
spinner xx "" pos:[13,24] width:93 height:16
on btn1 pressed do
modPanel.addModToSelection (Shell ()) ui:on
$.modifiers[#Shell].innerAmount = xx.value
$.modifiers[#Shell].outerAmount = xx.value
xx is the value i need to divide by two.
another quick question: spinner is the best option to catch this values? what other option can i use?
thanks in advance,
Jsrocha
ops
well then just do so :D You might also want to give your spinner a range, default value, scale and type:
I think a spinner is best for this, cause you get a number from it that you can use directly. You could also use an edittext field to input values, but would have to check if the user did type in a number or a character to prevent crashes.
Hey br0t, thanks a lot, it worked just fine! :)
cheers,
Jsrocha
