disable (Off) all modifiers on selected objects
By harumscarum · 2014-12-26
need simple hotkey script to disable (make it Off) all modifiers on selected objects
appreciate any help
Comments (10)
Geoff Hodbod
Can't get this to work in 2016 sp2
Tried this and no command panel comes up in 3ds max 2016.
Thanks for any help.
Reply to Geoff Hodbod
Works fine in max2017
Try this version. Run this macro and in the category "bgaTools" drag n drop this on your toolbar. When you hold SHIFT and press this button all modifiers of selected object will turn on else on single click will turn off
macroScript ModsOnOff category:"bgaTools" toolTip:"ModsOnOff"
if selection.count == 0 then messagebox "Select some object first!" title:"Warning" beep:off else
local modpanel = GetCommandPanelTaskMode()
with undo off with redraw off
for o in selection where o.modifiers.count > 0 do o.modifiers.enabled = keyboard.shiftPressed
if modpanel == #create then (setCommandPanelTaskMode #modify ; setCommandPanelTaskMode #create)
else (setCommandPanelTaskMode #create ; setCommandPanelTaskMode #modify)
Yup. Create two macros from this code
-- TURN ON MODIFIERS
	name = GetCommandPanelTaskMode()
	for o in selection where o.modifiers.count > 0 do o.modifiers.enabled = on
	if name == #create then (setCommandPanelTaskMode #modify ; setCommandPanelTaskMode #create)
and this code
-- TURN OFF MODIFIERS
	for o in selection where o.modifiers.count > 0 do o.modifiers.enabled = off
harumscarum
thank you very much. could it be even simplier - hotkey toggle?
harumscarum
thanks!
but it work only in one way - to ON all modifiers
Reply to harumscarum
No. Works in both ways. You need to use each FN separately.
Anyway here is the tool
rollout bgaRoll "on | off"
fn toggleMods objs mode:on =
if objs.count == 0 then messagebox "Select some object first!" title:"Warning" beep:off else
for o in objs where o.modifiers.count > 0 do o.modifiers.enabled = mode
button btn_on "TurnOn" pos:[5,5] width:45 height:18
button btn_off "TurnOff" pos:[55,5] width:45 height:18
on btn_on pressed do toggleMods selection
on btn_off pressed do toggleMods selection mode:off
createDialog bgaRoll 105 28 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
for m = 1 to o.modifiers.count do o.modifiers[m].enabled = mode
-- turn off all modifiers
-- turn on all modifiers
harumscarum
thank you very much!
thanks! work like a charm. is it possible to make it as toggle on/off?
for m = 1 to o.modifiers.count do o.modifiers[m].enabled = off
max create mode
