Detach, align and replace Script needed
By sedus69 · 2014-10-07
Hi, I looking for someone to create a script that meet my requirements. I ll pay for it, 100€ and feel free to post it as an Opensource after. I made a video, I try to explain what I m looking for: http://www.studiogrenade.com/capt/Detach%20replace%20align.html
The main purpose is to align and object along a triangle, or anything you think is better.
But those object are imported LOOSING their pivot point (sorry)
Than I want to Replace or Place and align a serie of object in 3dsMax onto those object : Objet, Vproxy, Light.... as Instance or copy
Realy look at the video, because, my english is so so bad.
the video shows you what I Manually do, with of course takes forever
The first part in Archicad, is BEcause I want to Put some marker into that software, and use them into 3dsmax.
Is it really necessary to detach triangles and reset these transform?
I already have solution on this forum in case when you have quads but also i'm have solution when you have triangles (not on forum).
Easier workflow will be.
- Detach all triangles that you need from your mesh object. This will be target object where on each triangle you can clone and align some scene object (source object).
- Select only one vert of each triangle to define direction ei. axis of orientation.
- And done
Hi barigazy
So sorry if you answer me in PM, because I can'f find where Personnal message goes on this website.
I found them once, and... no more.
So If you write to me, can't remember where I write back to you.
Reply to sedus69
The PM from this site goes to the email that you used to register in the site. They can be in the SPAM folder.
Triangle is just a suggestion because It help me into ARCHICAD to point a direction. as I need to keep of this orientation.
I can't have a solution where I need to select one vertex of every single triangle. It can be very long to select on each and every triangle.
My solution is to mass populate :
Import exact position of "Marker" to replace with (sometimes more than 80)
Import exact position of "Marker" to replace with object bench, garbage, Ceilling lamps...
I know I can Put them into 3dsmax directly, BUT, The plans I work with are HUGE. And it is far more easier for me to pu a "marker" into Archicad.
this is why I need to point a direction.
BUt as I export form Archicad every information about pivot point is lost.
But I still have UVWmap info on each face.
