Default snap item settings
By myfrankie · 2021-06-16
Each time you start 3ds Max 2022 capture, the default setting is grid point. Can you create an MS file and change it to three options: perpendicular foot, endpoint and midpoint, which are the default capture mode for software startup? Add: snap to frozen objects and enable axis constraints to unhide rubber band options.
