Hi
Is it a hard script that will do batch adding CoronaColorCorrect map on diffuse slots of selected objects which already have ready material or multi material?
By Suhiro · 2020-11-02
Hi
it might be a bit late but i've just made a script that does what you need, check here:
http://www.scriptspot.com/3ds-max/scripts/coronacolorcorrection-auto
also check http://www.scriptspot.com/3ds-max/scripts/corona-material-automator, you might be interested as well
Different max materials have different property names that corresponds to diffuse slot. If you know exact property name it is trivial to add some map in between.
