Corona Round Edges Script
By Simon · 2018-08-10
Hi guys
I use Coronaroundedges a lot for adding chamfering around mass geometry - is there a way to have a script automate this for me?
So ideally i would want to keep the bump map that is already in the slot and when the corona round edges is added to the bump slot, it automatically puts the existing bump map within the 'additional bump mapping' slot of the corona round edges texmap.
Is this possible?
Cheers
S
crystal3d
good idea
, add round edges to selected objct's materials.
it would be a good automation
pixamoon
How do you add Corona round edges int bump slot ? Is it in Slate or Compact Material Editor ?
Best,
Pixamoon
Reply to pixamoon
Simon
Hi Pixamoon
I use the compact material editor - thanks for the reply.
Reply to Simon
pixamoon
But if you create new bump in place of old - max doesn't ask if you want to "Keep old map as sub-map ?"
Reply to pixamoon
Simon
Hi Pixamoon
Yes it does - i put it as a sub map - but i want to automate this as i do it several times
