Convert editMesh to editpoly all objects but keep and convet instances
By Mahmud Esad · 2015-08-18
I need a script converting Editable mesh to editable poly conversion. But ı want to keep instance objects. is there anyone has something like this ?
İs it possible ?
pixamoon
Hi Fajar,
not if next line after "add modifier" is "collapse to Edit_Poly"...
- because all instances of "o" will be collapsed to Edit_poly too...
- that's mean they will be skipped later by ".. where classof o == Editable_mesh do ..."
of course this don't work if you "--" turn off collapse line, do you agree ?
About your code:
- it should be "appendifunique" otherwise same object will be collected multiple times (so "--add something here...." will be also repeated few times on the same object)
- "if firstOnly.count > 1 do" it will collects only instanced objects
- what about other selected objects which don't have any instance ?
(qestion was about convert "all objects" to EditPoly but keep instances)
- why "firstOnly[firstOnly.count-1]" not just firstOnly[1] ?
I think your code should look this way:
firstInstances = #()
for o in selection do (
	InstanceMgr.GetInstances o &Arr
	if Arr.count > 1 then
		appendifunique firstInstances Arr[1]
		appendifunique firstInstances o
--print firstInstances
if firstInstances.count != 0 do --add something here....
or even:
what do you think ?
fajar
if its intance we just need the first node only...say bout using InstanceMgr.GetInstances...
			InstanceMgr.GetInstances o &firstOnly
				append firstInstances firstOnly[firstOnly.count-1]
if object added modifer while the object itself is intance then if it added more than two modifier it'll result to add modifer 2xobject in selection count per object...
say something like this
for o in selection where classof o == Editable_mesh do (
	addmodifier o (Poly_Select())
		addmodifier o (Cloth())
	--maxOps.CollapseNodeTo o 1 off
pixamoon
try this:
for selected objects only:
for whole scene:
for o in geometry where classof o == Editable_mesh do (
cheers,
Pixamoon
