Hi guys, I'm a noob here and need your helps (partially at least). I have a request to made a 3D object out from 2D objects (which happen to be in form of image).
Generally here is what I thought logicly on matters,
First, I upload the necessary pics/images to 3Dsmax console (my theory on making 3D object you will at least required TWO image that will be the 'front' and the 'side' of the object you wish to generate)
Second, this image 'automatically' generate has a decal/line/mesh/poly.
Third, I simply 'pull' the 'shaped' image from the two and line them up together to make a 3D version of the appeared image.
What I achieve so far are just only the first, solve by blue_print.ms (blue print script, let you upload the image on the place you want).
Now it just remain the second and third problem, if anyone can help me on this one I'll be very very very appreciated.
i have no idea :) ..
but hey .. at least a response
