connect selected edges for every given distance
By gh0st · 2012-04-05
i am looking for a script that will connect selected edges for every given distance provided by a spinner.
For example: if i enter 10 cm in the spinner, it will connect the selected edges for every 10cm.
Reply to harumscarum
Furyofaseraph
Distance Issues...
Greetings,
I'm not sure if you are the original author of this script, and I realize it is 2 years old, but I've found an issue: It seems as though it only keeps the distance between points accurate if the length of the edges you are connecting is a multiple of the intended spacing.
Is there a way around this?
Jos Balcaen
Distance connect
