Hallo.
I am new on 3d max script and I have an idea to do a quick layer creator script.
My purpose is to create a few defined layer by base name entered in edittext. My script was half completed but I was stuck on other half of the codes. If someone could tell me how can I combine two different arrays by string variables into one array string I will be thankful to answerer.
This is my script written through me for the purpose.
----- LayerCreator 0.1 -----
----- Global Varibles ------
global crtNewLayer ----- varable to create new layer
global lyrDefNames ----- string array for
global lyrNames
global bsNames
----- Definition of Global Variables --------
lyrDefNames= # ("_Mesh","_Controller","_Hiden") ------- layer names was defined in array
lyrNames=
fn cmbLyrNames=
if bsNames != undefined then
for n = 1 to lyrDefNames.count do
i= n
x=bsNames
append x lyrNames [i]
crtNewLayer =
---- The function for Create New Layers button ------
fn realiseLayers=
for n = 1 to lyrDefNames.count do -------- a loop to create each layer
i= n
x= lyrDefNames
y= layermanager.getlayerfromname x [i]
z= layermanager.newlayerfromname x [i]
if y != undefined then
z
rollout LayerCreator "LayerCreator 0.1" width:280 height:112
button crtLayers "Create New Layers" pos:[0,56] width:280 height:37 enabled:true toolTip:""
editText lyrBsName " Base Name of Layers" pos:[4,24] width:270 enabled:true
on lyrBsName entered txt do
if lyrBsName.text != "" then
bsNames = # (lyrBsName.text as string)
on crtLayers pressed do
crtNewLayer ()
lyrNames()
createdialog LayerCreator
Comments (9)
I can add afew more options on the script.
It's difficult to understand what do you want to achive here.
Just tell me this.
If I type word in textbox let say "NewObjects" and press the "Create New Layers" button what should look final layer name string?
Thanks for answer.
The final layer name will be the word in textbox plus every given layer name in the script. Such as " textbox" plus "_Mesh" after they had been combined will be "textbox_Mesh". The script will be an easy way to create specific layer names in complex scenes.
Ok. But U have array with predefined names (prefix)
How can script know when need to use one of this items in combination with textbox text?
The script is not ready yet completely. Predefined array is necessary for its purpose.
This is the simple concept
try(destroyDialog ::LayerCreator)catch()
label lbl "Layer Name: Prefix:" pos:[5,5]
editText lyrBsName "" pos:[0,20] width:190 height:17
dropdownlist ddlist "" pos:[195,18] width:80 items:#("_Mesh","_Controller","_Hiden")
button crtLayers "Create New Layers" pos:[5,45] width:270
on LayerCreator open do setFocus lyrBsName
if lyrBsName.text == "" then messagebox "Define Layer Name" title:"Warning" beep:off else
layName = lyrBsName.text + ddlist[ddlist.selection]
if LayerManager.getLayerFromName layName == null then LayerManager.newLayerFromName layName else
messagebox "This layer already exists!" title:"Warning" beep:off
createdialog LayerCreator 280 70 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Your idea is good but it's not what I am looking for.
Here it is my last codes for my idea, I want to add a few more things before publishing final result of script.
global lyrNames
global bsName
lyrDefNames= #()
lyrNames= #()
fn cmbNames=
if bsName != "" then
for i= 1 to lyrDefNames.count collect
append lyrNames (bsName + lyrDefNames [i])
crtNewLayer =
fn realiseLayers=
for n = 1 to lyrNames.count do -------- a loop to create each layer
i= n
x= lyrNames
z
rollout LayerCreator "LayerCreator 0.1" width:280 height:208
edittext lyrBsName " Base Name of Layers" pos:[13,7] width:254 height:17 enabled:true
button crtLayers "Create New Layers" pos:[8,160] width:264 height:37 enabled:true toolTip:""
groupBox Layers "Select Layers for Scene Objects" pos:[8,40] width:264 height:112
checkbox _Controller "Controller Objects" pos:[16,88] width:120 height:24
checkbox _Cameras "Cameras" pos:[144,88] width:120 height:24
checkbox _Mesh "Mesh Objects" pos:[16,56] width:128 height:24
checkbox _Hiden "Hiden Objects" pos:[16,120] width:120 height:24
checkbox _Lights "Light Objects" pos:[144,56] width:120 height:24
checkbox _Particles "Particles" pos:[144,120] width:120 height:24
on _Controller theState do
objController= "_Controller"
append lyrDefNames objController
on _Cameras changed theState do
objCameras="_Cameras"
append lyrDefNames objCameras
on _Mesh changed theState do
objMesh="_Mesh"
append lyrDefNames objMesh
on _Hiden changed theState do
objHiden="_Hiden"
append lyrDefNames objHiden
on _Lights changed theState do
objLights="_Lights"
append lyrDefNames objLights
on _Particles changed theState do
objParticles="_Particles"
append lyrDefNames objParticles
bsName = lyrBsName.text
cmbNames ()
on crtLayers pressed do crtNewLayer ()
Post your code inside(without the quotes) to make it readable.
[""code""]
{""/code""}
FORUM RULE
http://www.scriptspot.com/forums/3ds-max/general-scripting/kredka-strike…
