close caddy menu
By paulius3d · 2018-12-06
Hi, I am making optimization for connecting edges on mose movement. But dont know how to close caddy dialog. Previously I used "UIAccessor.CloseDialog t[1]", but it stoped working, you will find it in a full script bellow. How can I close this caddy menu? Thanks.
macroScript connectPreview_ category:"paulius3d" buttonText:"connectPreview" tooltip:"_connectPreview" -- CONNECT PREVIEW
local kasPazymeta
startPosX = mouse.pos.x
startPosY = mouse.pos.y
--print startPos
if $ != undefined and classof $ == Editable_Poly then( -- ar editPoly
if subobjectLevel == 2 then( -- ar Edge
if (polyOp.getEdgeSelection $) as string == (#{}) as string then( --ar pazymeta edge
messagebox "select edge/edges"
)else()
tool foo(
on mousePoint clickno do( -- ant paspaudimo darom
if clickno <= 2 then(
macros.run "paulius3d" "connectGrip_"
for child in (windows.getChildrenHWND 0 parent:#max) where (child[5] == "Connect Edges") do( -- dialogo pozicija ties 0
windPosAndSize = windows.getWindowPos child[1]
windows.setWindowPos child[1] 0 0 windPosAndSize.w windPosAndSize.h true
)else (
$.EditablePoly.ConnectEdges ()
t = windows.getChildHWND 0 "Connect Edges"
DestroyDialog t[1]
--UIAccessor.CloseDialog t[1]
#stop
on mouseMove clickno do(
try(
$.connectEdgeSlide = ((viewPoint.x - startPosX)/3)
$.connectEdgeSegments = (1+abs((viewPoint.y - startPosY-100)/300))
)catch false
on mouseAbort clickno do(
try(
t=windows.getChildHWND 0 "Connect Edges"
)catch false
startTool foo
else(
subobjectLevel = 2
messagebox "make edge selection and run again"
)else messagebox "select Editable poly"
Comments (11)
paulius3d
Hi, thanks for taking time to check my problem. Yes, caddy dialog appears when I am trying to run macro to have connect dialog (connectGrip_). I know I could use old style connect dialog, but For other places, like extrude, bridge and so on, I quite like caddy menu. Just wondering is there is a simple command to close that dialog.
Reply to miauu
paulius3d
Hi, I have replaced that macro to default macros, that shoud run on any 3ds max system. The script works as follow: If you have Editable Poly selected, in Edges subobjectt level. You have to select one edge and run the script. First macro selects the ring of edges, the second macro runs connect function. Later new edges move according to mouse movement, horizontaly shifts them to the sides, if you move verticaly, that adds some extra edges. Because of the mouse movement, you have to run this script as maxro, and assign the shortcut, as the mouse initial position matters. You can download as script file here:
https://mega.nz/#!LyYUGYSJ!H26F_vidiRFNNI31JcKyrEG2w4GcYMofFoIAUa6kIfo
or copy from bellow. Thanks a lot.
local kasPazymeta
--print startPos
)else()
tool foo(
macros.run "Editable Polygon Object" "EPoly_Select_Ring"
macros.run "Ribbon - Modeling" "ConnectEdgesOptions"
)else (
DestroyDialog t[1]
#stop
try(
)catch false
try(
)catch false
startTool foo
else(
subobjectLevel = 2
Reply to paulius3d
pixamoon
Sorry it might be late, but did you try to print if there is any windows found with "Collect Edges"
Try to add:
print t.count
or:
messageBox t.count
after:
Best,
Pixamoon
Reply to pixamoon
paulius3d
That didn't work. Caddy is some kind of "not window" type dialog.
Reply to paulius3d
Panteleev Sergey
Try this one.
But note that for some reason there's no resulting edges selection in caddy mode.
	qtwidgets = for w in UIAccessor.GetPopupDialogs() where (windows.getHWNDData w)[4] == "QWidget" collect w
	if qtwidgets.count > 2 then
		-- caddy mode is active
		button_hwnd = qtwidgets[ qtwidgets.count ] -- last control is Apply button
		windows.sendMessage button_hwnd 0x201 1 0 -- left mouse click
	#stop
and
caddy is absolutely a window
see for yourself
	for w in UIAccessor.GetPopupDialogs() do
		format "% % \"%\" %\n" (UIAccessor.GetWindowClassName w) (UIAccessor.IsWindow w) (UIAccessor.GetWindowText w) (windows.getWindowPos w)
ok, apply and cancel buttons have 22x22 dimensions in my 2014 max, don't know if it's the case for all the rest. But anyway, knowing control position you can find its handle pretty easily
btw. you can use Spy++ to check what messages are sent to any max control
Reply to Panteleev Sergey
paulius3d
I tried your script, but it doesnt work on 3dsmax 2018
t: undefined
--qtwidgets: #()
--button_hwnd: undefined
Tried couple of modifications, and still didnt find a solution. Also installed spy++, played with it a bit and also didnt find a solution, or required "line" to solve that. For now I am using this script, that works well when disabling caddy controls, but as I mentioned previosly I quite like caddy controls in overal.
ps. dont know how to insert a script here properly :(
script
local kasPazymeta
--print startPos
)else()
tool foo(
)else (
try(
uiaccessor.closedialog (windows.getchildhwnd 0 "Connect Edges")[1]
)catch false
#stop
try(
)catch false
try(
)catch false
startTool foo
else(
subobjectLevel = 2
Reply to paulius3d
Panteleev Sergey
<code> ... code goes here ... </code>
but I won't be able to help you with anything above 2014 anyway
Which line of your code is used to show the caddy dialog? This one: macros.run "paulius3d" "connectGrip_" or another?
Whay you not switch to old style dialogs, not to caddy?
