Clone objects and add a name extention
By Andrew · 2013-11-04
Hey guys.. looking for a script that will clone All selected objects, and add a name extension to the original object's names.
For example Box_01 and Box_02 cloned to Box_01_New-text-here and Box_02_New-text-here, than create a new layer and be able to name that for the group of selected objects that were cloned.
Comments (13)
Andrey
Hello Miauu
Tell me how to fix the code?
In the process of renaming objects, the name is skipped - 001, 003, 005 ... I can not find a solution.
Help me please.
Reply to Andrey
How I can reproduce the problem? How many objects I have to select, what suffix I have to use?
Reply to miauu
Andrey
I tried to add a name selection when copying.
newNodesArr.name = Uniquename bg_8.text
The problem occurs when you copy the same name again - the script skips the number.
Example: copy of “Name 001” = “Name 003”, “Name 005” ...
Besides this problem, the script does everything right.
As a result of copying, it is necessary to obtain the selected name and serial number of the object - "Name 001", "Name 002", "Name 003" ...
If you do not enter a name, then get - "001", "002", "003" ...
Ideally, if the object to be copied is named “Name 001_01” or “Name 001_001”, when copying, you need to get “Name 002”, “Name 003” ...
Please tell me how to write it right?
Thanks your help!
Try this:
	fn uniqueNodeName node = if isValidNode node do
				s = filterstring node.name "_"
				newName = s[1] + "_"
				if s.count == 1 then
					newName += "001"
					--	"this"
					newName += formattedPrint ((trimleft s[2] "0") as integer + 1) format:"03d"
					--	"or this"
-- 					newName = uniqueName node.name
				newName
Reply to miauu
Andrey
Duplicates
The script creates duplicates when you copy the original object again.
Example:
When copying "001" we get "001_001", "001_002", "001_003" ...
When we copy the original object "001" again, we get the same "001_001", "001_002", "001_003" ... however, must continue to "001_004", "001_005" ...
Reply to Andrey
Try this:
--	"this"
					-- newName += formattedPrint ((trimleft s[2] "0") as integer + 1) format:"03d"
					--	"or this"
Reply to miauu
Andrey
Alas.
I have added a line. Now numbering skips the unit - 002, 004, 006 ...
Andrew
Perfect as always Miauu!! thanks!
Reply to miauu
Andrey
Hello Miauu
I took part of your code to copy the camera along with its target and added another code to it. It works well, without errors.
Please tell me how to make the code work only for cameras.
И как добавить к имени «_001» вместо «_01».
Example:
copy of "Camera 001" = "Camera 001_001"
copy of "Camera 001_001" = "Camera 001_002"
That's what happened - Copy camera.
Thanks for your help.
Reply to Andrey
I am not sure if the naming will works properly.
	global rol_Clone
	try(destroyDialog rol_Clone)catch()
	rollout rol_Clone ""
		button btn_clone "Clone"
		on btn_clone pressed do
			--	"get all cameras in the scene"
-- 			local objToCloneArr = for o in cameras where classOf o != TargetObject collect o
			--	"get cameras among selected objcets"
			local objToCloneArr = for o in selection where superClassOf o == camera and classOf o != TargetObject collect o
			local newObjsArr = #()
				fn filtername nodeName suffix = (e = filterstring nodeName "_"; e[2] = suffix ; e)
				local oldName = filtername node.name "001", newName = oldName[1]+"_001"
				while (getNodeByName newname) != undefined do
					newName = oldName[1] + "_" + (string = formattedPrint ((trimleft oldName[2] "0") as integer + 1) format:"03d")
					oldName = filtername newName string
				newName
			for o in objToCloneArr do
				local newNodesArr = #()
				maxOps.CloneNodes o cloneType:#copy newNodes:&newNodesArr
				newNodesArr[1].name = uniqueNodeName o
				append newObjsArr newNodesArr[1]
			select newObjsArr
	createdialog rol_Clone
Reply to miauu
Andrey
Thanks Miauu
Copying only cameras works as it should. Renaming does not work quite right.
Example: 001, 003, 002, 005, 004, 007 ...
Perhaps you need to record differently. In any case, thanks, it was useful information.
I will look for other ways to rename.
	global rol_Clone
		edittext et_suffix "Suffix:" text:""
		edittext et_layerName "Layer Name:" text:""
		group "Offset:"
			spinner spn_offsetX "X:" range:[-1e9,1e9,0] type:#worldunits
			spinner spn_offsetY "Y:" range:[-1e9,1e9,0]  type:#worldunits
			spinner spn_offsetZ "Z:" range:[-1e9,1e9,0]  type:#worldunits
			local objToCloneArr = selection as array
				maxOps.CloneNodes o offset:[spn_offsetX.value,spn_offsetY.value,spn_offsetZ.value] expandHierarchy:false cloneType:#copy newNodes:&newNodesArr
				newNodesArr[1].name = o.name + et_suffix.text
			if newObjsArr.count != 0 do
				if et_layerName.text != "" then
					if LayerManager.getLayerFromName et_layerName.text == undefined 	then
						newLayer = LayerManager.newLayerFromName et_layerName.text
						for o in newObjsArr do newLayer.addNode o
						newLayer = LayerManager.getLayerFromName et_layerName.text
