Clear Multiple channels from an object
By bolegna · 2011-12-10
Hello, I need to clear multiple channels from an object.
I tried this as a test:
for x = 5 to 50 do
channelInfo.ClearChannel $ x
[this one has 50 map channels, but I need to clear from a specified number to a another specified number]
It applied all 45 "uvw mapping clear" modifiers each with an ascending number to the stack but only cleared one of them (50) when I collapsed the stack.
If I do this manually in the map channel info dialogue but right clicking each channel and clearing it, it works – but I don’t want to do that for lots of objects with 90 channels each 
Thanks for any help
MaximilianPs
ChannelInfo.ClearChannel
Sorry for the 5 years necromancy but I guess it could be useful ;=)
Based on selection, this will clear all Channel, you could add the channel number as your n needs.
This is useful 'cause unity fbx exporter will crash 3DS Max if channels are present!
for i in selection do
  channelinfo.clearchannel i 2
  channelinfo.clearchannel i 3
Obviously:
DO A BACKUP BEFORE TRY IT !!!
I cannot be considered responsable for headache, monitor explosion, heart attacks
LittleLordPotala
The solution
We must directly add the modifier in a descending loop :
for i = 50 to 5 by -1 do
(addmodifier $ (UVW_Mapping_Clear mapID:i); collapsestack $)
LittleLordPotala
A workaround...
As the function "channelInfo.ClearChannel" does not work inside a loop,
I made an interface with spinners.
In the "channel" spinner, just enter the last channel of the list and it
automatically delete this channel, then click and hold-down the down-buton of the spinner and it will delete the channels very fast.
I added a "stop to" spinner as a protection to keep all the channels greater than this value.
