"Clear Materials from Selected" command? (Is this right?)
By kinggambit · 2017-12-05
Embarrassingly enough, I've tried for the past couple days to write a simple script for this but I've realized I'm hopelessly bad at maxscript. Shouldn't this work if I ran it?
macroScript ClearMaterialSelected
category:"# Scripts"
toolTip:"Clear Material"
 $. mat = null
	if selection.count != 0 do selection.material = undefined
Reply to miauu
Vojtech Cada
You don't even need the if test if using selection. I think the original problem might be confusing what scripts vs macroscripts do, macro will do 'nothing' when run as a script, it will only register an action that can be called from global search, assigned hotkey or UI item
